%3CLINGO-SUB%20id%3D%22lingo-sub-30443%22%20slang%3D%22en-US%22%3ENuovo%20componente%20aggiuntivo%20di%20analisi%20di%20emergenza%20per%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-30443%22%20slang%3D%22en-US%22%3E%3CP%3EUn'analisi%20di%20contingenza%20determina%20se%20esiste%20una%20relazione%20tra%20due%20variabili%20categoriali.%20Un%20addetto%20alla%20ristorazione%2C%20ad%20esempio%2C%20potrebbe%20essere%20interessato%20a%20sapere%20se%20le%20selezioni%20di%20entrata%20in%20un%20evento%20erano%20correlate%20al%20sesso%2C%20dati%20i%20seguenti%20dati%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_1.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13366%22%20alt%3D%22IMAGE_1%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_1.png%22%20width%3D%22401%22%20height%3D%2277%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELa%20piattaforma%20di%20emergenza%20in%20%3CA%20href%3D%22http%3A%2F%2Fjmp.com%2Fsoftware%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20JMP%20%3C%2FA%3E%20richiede%20che%20le%20variabili%20X%20e%20Y%20siano%20contenute%20in%20due%20colonne%2C%20con%20il%20conteggio%20delle%20celle%20in%20un%20terzo%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_2.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13365%22%20alt%3D%22image_2%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_2.png%22%20width%3D%22328%22%20height%3D%22208%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECon%20il%20%22%20%3CA%20href%3D%22http%3A%2F%2Fsupport.sas.com%2Fdemosdownloads%2Fdownarea_t4.jsp%3FproductID%3D114635%26amp%3Bjmpflag%3DN%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20%22Componente%20aggiuntivo%20(formato%20tabella)%22%20aggiuntivo%20%3C%2FA%3E%20%2C%20sviluppato%20appositamente%20per%20studenti%20e%20altri%20che%20sono%20nuovi%20a%20JMP%2C%20%C3%A8%20possibile%20avviare%20un'analisi%20di%20contingenza%20con%20dati%20organizzati%20in%20formato%20%22crosstab%22%2C%20senza%20dover%20prima%20impilare%20i%20dati%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_3.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13364%22%20alt%3D%22IMAGE_3%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_3.png%22%20width%3D%22441%22%20height%3D%2285%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBasta%20specificare%20le%20variabili%20come%20mostrato%20qui%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_4-e1399859999927.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13363%22%20alt%3D%22IMAGE_4%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_4-e1399859999927.png%22%20width%3D%22550%22%20height%3D%22240%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIl%20componente%20aggiuntivo%20crea%20il%20rapporto%20di%20emergenza%20e%20include%20pulsanti%20che%20consentono%20di%20scambiare%20facilmente%20le%20righe%20e%20le%20colonne%20del%20report%2C%20se%20lo%20si%20desidera%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_5.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13362%22%20alt%3D%22IMAGE_5%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_5.png%22%20width%3D%22335%22%20height%3D%22463%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESe%20l'opzione%20%22Mostra%20nuova%20tabella%22%20%C3%A8%20selezionata%2C%20il%20componente%20aggiuntivo%20genera%20anche%20una%20tabella%20impilata%20contenente%20uno%20script%20che%20avvier%C3%A0%20la%20piattaforma%20nel%20modo%20standard%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_6.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13361%22%20alt%3D%22IMAGE_6%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_6.png%22%20width%3D%22420%22%20height%3D%22232%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fsupport.sas.com%2Fdemosdownloads%2Fdownarea_t4.jsp%3FproductID%3D114635%26amp%3Bjmpflag%3DN%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20Questo%20componente%20aggiuntivo%20%3C%2FA%3E%20%2C%20insieme%20a%20molti%20altri%2C%20%C3%A8%20disponibile%20su%20%3CA%20href%3D%22http%3A%2F%2Fsupport.sas.com%2Fdemosdownloads%2Fsysdep_t4.jsp%3FpackageID%3D000416%26amp%3Bjmpflag%3DY%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20Scambio%20file%20JMP%20%3C%2FA%3E%20.%20(Per%20l'accesso%20%C3%A8%20necessario%20un%20profilo%20SAS%20gratuito.)%3C%2FP%3E%3C%2FLINGO-BODY%3E
New contingency analysis add-in for JMP
A contingency analysis determines whether there is a relationship between two categorical variables. A caterer, for example, might be interested in knowing whether entrée selections at an event were related to gender, given the following data:
image_1
The contingency platform in JMP requires the X and Y variables to be contained in two columns, with the cell counts in a third:
image_2
With the “Contingency (Table Format)” add-in, developed especially for students and others who are new to JMP, you can launch a contingency analysis with data that is arranged in “crosstab” format, without having to stack the data first:
image_3
Simply specify the variables as shown here:
image_4
The add-in creates the contingency report and includes buttons that let you easily swap the rows and columns of the report if desired:
image_5
If the “Show New Table” option is selected, the add-in also generates a stacked table containing a script that will launch the platform in the standard manner:
image_6
This add-in, along with many others, is available on the JMP File Exchange. (A free SAS profile is needed for access.)
Article Labels
