%3CLINGO-SUB%20id%3D%22lingo-sub-30443%22%20slang%3D%22en-US%22%3ENouveau%20compl%C3%A9ment%20d'analyse%20des%20impr%C3%A9vus%20pour%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-30443%22%20slang%3D%22en-US%22%3E%3CP%3EUne%20analyse%20de%20contingence%20d%C3%A9termine%20s'il%20existe%20une%20relation%20entre%20deux%20variables%20cat%C3%A9gorielles.%20Un%20traiteur%2C%20par%20exemple%2C%20pourrait%20%C3%AAtre%20int%C3%A9ress%C3%A9%20%C3%A0%20savoir%20si%20les%20s%C3%A9lections%20d'entr%C3%A9es%20lors%20d'un%20%C3%A9v%C3%A9nement%20%C3%A9taient%20li%C3%A9es%20au%20genre%2C%20%C3%A0%20partir%20des%20donn%C3%A9es%20suivantes%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_1.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13366%22%20alt%3D%22image_1%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_1.png%22%20width%3D%22401%22%20height%3D%2277%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELa%20plate-forme%20de%20contingence%20en%20%3CA%20href%3D%22http%3A%2F%2Fjmp.com%2Fsoftware%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20JMP%20%3C%2FA%3E%20exige%20que%20les%20variables%20X%20et%20Y%20soient%20contenues%20dans%20deux%20colonnes%2C%20avec%20le%20nombre%20de%20cellules%20dans%20une%20troisi%C3%A8me%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_2.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13365%22%20alt%3D%22image_2%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_2.png%22%20width%3D%22328%22%20height%3D%22208%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAvec%20le%20%22%20%3CA%20href%3D%22http%3A%2F%2Fsupport.sas.com%2Fdemosdownloads%2Fdownarea_t4.jsp%3FproductID%3D114635%26amp%3Bjmpflag%3DN%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20Compl%C3%A9ment%20%C2%ABContingency%20(Table%20Format)%C2%BB%20%3C%2FA%3E%20sp%C3%A9cialement%20d%C3%A9velopp%C3%A9%20pour%20les%20%C3%A9tudiants%20et%20les%20d%C3%A9butants%20de%20JMP%2C%20vous%20pouvez%20lancer%20une%20analyse%20de%20contingence%20avec%20des%20donn%C3%A9es%20organis%C3%A9es%20au%20format%20%C2%ABtableau%20crois%C3%A9%C2%BB%2C%20sans%20avoir%20%C3%A0%20empiler%20les%20donn%C3%A9es%20au%20pr%C3%A9alable%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_3.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13364%22%20alt%3D%22image_3%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_3.png%22%20width%3D%22441%22%20height%3D%2285%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESp%C3%A9cifiez%20simplement%20les%20variables%20comme%20indiqu%C3%A9%20ici%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_4-e1399859999927.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13363%22%20alt%3D%22image_4%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_4-e1399859999927.png%22%20width%3D%22550%22%20height%3D%22240%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELe%20compl%C3%A9ment%20cr%C3%A9e%20le%20rapport%20de%20contingence%20et%20comprend%20des%20boutons%20qui%20vous%20permettent%20d%E2%80%99%C3%A9changer%20facilement%20les%20lignes%20et%20les%20colonnes%20du%20rapport%20si%20vous%20le%20souhaitez%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_5.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13362%22%20alt%3D%22image_5%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_5.png%22%20width%3D%22335%22%20height%3D%22463%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESi%20l'option%20%C2%ABAfficher%20la%20nouvelle%20table%C2%BB%20est%20s%C3%A9lectionn%C3%A9e%2C%20le%20compl%C3%A9ment%20g%C3%A9n%C3%A8re%20%C3%A9galement%20une%20table%20empil%C3%A9e%20contenant%20un%20script%20qui%20lancera%20la%20plate-forme%20de%20mani%C3%A8re%20standard%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_6.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13361%22%20alt%3D%22image_6%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_6.png%22%20width%3D%22420%22%20height%3D%22232%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fsupport.sas.com%2Fdemosdownloads%2Fdownarea_t4.jsp%3FproductID%3D114635%26amp%3Bjmpflag%3DN%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20Ce%20compl%C3%A9ment%20%3C%2FA%3E%20%2C%20avec%20beaucoup%20d%E2%80%99autres%2C%20est%20disponible%20sur%20le%20%3CA%20href%3D%22http%3A%2F%2Fsupport.sas.com%2Fdemosdownloads%2Fsysdep_t4.jsp%3FpackageID%3D000416%26amp%3Bjmpflag%3DY%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20Echange%20de%20fichiers%20JMP%20%3C%2FA%3E%20.%20(Un%20profil%20SAS%20gratuit%20est%20n%C3%A9cessaire%20pour%20l'acc%C3%A8s.)%3C%2FP%3E%3C%2FLINGO-BODY%3E
New contingency analysis add-in for JMP
A contingency analysis determines whether there is a relationship between two categorical variables. A caterer, for example, might be interested in knowing whether entrée selections at an event were related to gender, given the following data:
image_1
The contingency platform in JMP requires the X and Y variables to be contained in two columns, with the cell counts in a third:
image_2
With the “Contingency (Table Format)” add-in, developed especially for students and others who are new to JMP, you can launch a contingency analysis with data that is arranged in “crosstab” format, without having to stack the data first:
image_3
Simply specify the variables as shown here:
image_4
The add-in creates the contingency report and includes buttons that let you easily swap the rows and columns of the report if desired:
image_5
If the “Show New Table” option is selected, the add-in also generates a stacked table containing a script that will launch the platform in the standard manner:
image_6
This add-in, along with many others, is available on the JMP File Exchange. (A free SAS profile is needed for access.)
Article Labels
