%3CLINGO-SUB%20id%3D%22lingo-sub-30443%22%20slang%3D%22en-US%22%3ENuevo%20complemento%20de%20an%C3%A1lisis%20de%20contingencia%20para%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-30443%22%20slang%3D%22en-US%22%3E%3CP%3EUn%20an%C3%A1lisis%20de%20contingencia%20determina%20si%20existe%20una%20relaci%C3%B3n%20entre%20dos%20variables%20categ%C3%B3ricas.%20Un%20proveedor%2C%20por%20ejemplo%2C%20podr%C3%ADa%20estar%20interesado%20en%20saber%20si%20las%20selecciones%20de%20entradas%20en%20un%20evento%20se%20relacionaron%20con%20el%20g%C3%A9nero%2C%20dados%20los%20siguientes%20datos%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_1.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13366%22%20alt%3D%22imagen_1%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_1.png%22%20width%3D%22401%22%20height%3D%2277%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ELa%20plataforma%20de%20contingencia%20en%20%3CA%20href%3D%22http%3A%2F%2Fjmp.com%2Fsoftware%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20JMP%20%3C%2FA%3E%20requiere%20que%20las%20variables%20X%20e%20Y%20est%C3%A9n%20contenidas%20en%20dos%20columnas%2C%20con%20los%20conteos%20de%20celdas%20en%20una%20tercera%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_2.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13365%22%20alt%3D%22imagen_2%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_2.png%22%20width%3D%22328%22%20height%3D%22208%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECon%20el%20%22%20%3CA%20href%3D%22http%3A%2F%2Fsupport.sas.com%2Fdemosdownloads%2Fdownarea_t4.jsp%3FproductID%3D114635%26amp%3Bjmpflag%3DN%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20%22Contingencia%20(Formato%20de%20tabla)%22%20complemento%20%3C%2FA%3E%20Desarrollado%20especialmente%20para%20estudiantes%20y%20otras%20personas%20que%20son%20nuevas%20en%20JMP%2C%20puede%20iniciar%20un%20an%C3%A1lisis%20de%20contingencia%20con%20datos%20organizados%20en%20formato%20de%20%22tabla%20de%20referencias%22%2C%20sin%20tener%20que%20apilar%20los%20datos%20primero%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_3.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13364%22%20alt%3D%22imagen_3%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_3.png%22%20width%3D%22441%22%20height%3D%2285%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESimplemente%20especifique%20las%20variables%20como%20se%20muestra%20aqu%C3%AD%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_4-e1399859999927.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13363%22%20alt%3D%22imagen_4%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_4-e1399859999927.png%22%20width%3D%22550%22%20height%3D%22240%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EEl%20complemento%20crea%20el%20informe%20de%20contingencia%20e%20incluye%20botones%20que%20le%20permiten%20intercambiar%20f%C3%A1cilmente%20las%20filas%20y%20columnas%20del%20informe%20si%20lo%20desea%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_5.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13362%22%20alt%3D%22imagen_5%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_5.png%22%20width%3D%22335%22%20height%3D%22463%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESi%20se%20selecciona%20la%20opci%C3%B3n%20%22Mostrar%20nueva%20tabla%22%2C%20el%20complemento%20tambi%C3%A9n%20genera%20una%20tabla%20apilada%20que%20contiene%20una%20secuencia%20de%20comandos%20que%20iniciar%C3%A1%20la%20plataforma%20de%20la%20manera%20est%C3%A1ndar%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_6.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13361%22%20alt%3D%22imagen_6%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_6.png%22%20width%3D%22420%22%20height%3D%22232%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fsupport.sas.com%2Fdemosdownloads%2Fdownarea_t4.jsp%3FproductID%3D114635%26amp%3Bjmpflag%3DN%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20Este%20complemento%20%3C%2FA%3E%20%2C%20junto%20con%20muchos%20otros%2C%20est%C3%A1%20disponible%20en%20el%20%3CA%20href%3D%22http%3A%2F%2Fsupport.sas.com%2Fdemosdownloads%2Fsysdep_t4.jsp%3FpackageID%3D000416%26amp%3Bjmpflag%3DY%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20Intercambio%20de%20archivos%20JMP%20%3C%2FA%3E%20.%20(Se%20necesita%20un%20perfil%20SAS%20gratuito%20para%20el%20acceso.)%3C%2FP%3E%3C%2FLINGO-BODY%3E
New contingency analysis add-in for JMP
A contingency analysis determines whether there is a relationship between two categorical variables. A caterer, for example, might be interested in knowing whether entrée selections at an event were related to gender, given the following data:
image_1
The contingency platform in JMP requires the X and Y variables to be contained in two columns, with the cell counts in a third:
image_2
With the “Contingency (Table Format)” add-in, developed especially for students and others who are new to JMP, you can launch a contingency analysis with data that is arranged in “crosstab” format, without having to stack the data first:
image_3
Simply specify the variables as shown here:
image_4
The add-in creates the contingency report and includes buttons that let you easily swap the rows and columns of the report if desired:
image_5
If the “Show New Table” option is selected, the add-in also generates a stacked table containing a script that will launch the platform in the standard manner:
image_6
This add-in, along with many others, is available on the JMP File Exchange. (A free SAS profile is needed for access.)
Article Labels
