%3CLINGO-SUB%20id%3D%22lingo-sub-30443%22%20slang%3D%22en-US%22%3ENeues%20Add-In%20f%C3%BCr%20die%20Kontingenzanalyse%20f%C3%BCr%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-30443%22%20slang%3D%22en-US%22%3E%3CP%3EEine%20Kontingenzanalyse%20ermittelt%2C%20ob%20zwischen%20zwei%20kategorialen%20Variablen%20ein%20Zusammenhang%20besteht.%20Ein%20Caterer%20k%C3%B6nnte%20beispielsweise%20daran%20interessiert%20sein%20zu%20wissen%2C%20ob%20die%20Auswahl%20der%20Vorspeisen%20bei%20einer%20Veranstaltung%20geschlechtsspezifisch%20war.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_1.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13366%22%20alt%3D%22image_1%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_1.png%22%20width%3D%22401%22%20height%3D%2277%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDie%20Notfallplattform%20in%20%3CA%20href%3D%22http%3A%2F%2Fjmp.com%2Fsoftware%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20JMP%20%3C%2FA%3E%20erfordert%2C%20dass%20die%20X-%20und%20Y-Variablen%20in%20zwei%20Spalten%20enthalten%20sind%2C%20wobei%20die%20Zellzahlen%20in%20einer%20dritten%20Spalte%20enthalten%20sind%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_2.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13365%22%20alt%3D%22image_2%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_2.png%22%20width%3D%22328%22%20height%3D%22208%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMit%20dem%20%22%20%3CA%20href%3D%22http%3A%2F%2Fsupport.sas.com%2Fdemosdownloads%2Fdownarea_t4.jsp%3FproductID%3D114635%26amp%3Bjmpflag%3DN%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20Add-In%20f%C3%BCr%20Kontingenz%20(Tabellenformat)%20%3C%2FA%3E%20Sie%20wurde%20speziell%20f%C3%BCr%20Sch%C3%BCler%20und%20andere%2C%20die%20noch%20nicht%20mit%20JMP%20vertraut%20sind%2C%20entwickelt.%20Sie%20k%C3%B6nnen%20eine%20Kontingenzanalyse%20mit%20Daten%20starten%2C%20die%20im%20Kreuztabellenformat%20angeordnet%20sind%2C%20ohne%20die%20Daten%20zuvor%20stapeln%20zu%20m%C3%BCssen%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_3.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13364%22%20alt%3D%22image_3%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_3.png%22%20width%3D%22441%22%20height%3D%2285%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EGeben%20Sie%20einfach%20die%20Variablen%20wie%20hier%20gezeigt%20an%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_4-e1399859999927.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13363%22%20alt%3D%22image_4%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_4-e1399859999927.png%22%20width%3D%22550%22%20height%3D%22240%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDas%20Add-In%20erstellt%20den%20Kontingenzbericht%20und%20enth%C3%A4lt%20Schaltfl%C3%A4chen%2C%20mit%20denen%20Sie%20bei%20Bedarf%20problemlos%20die%20Zeilen%20und%20Spalten%20des%20Berichts%20austauschen%20k%C3%B6nnen%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_5.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13362%22%20alt%3D%22image_5%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_5.png%22%20width%3D%22335%22%20height%3D%22463%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWenn%20die%20Option%20%22Neue%20Tabelle%20anzeigen%22%20ausgew%C3%A4hlt%20ist%2C%20generiert%20das%20Add-In%20auch%20eine%20gestapelte%20Tabelle%20mit%20einem%20Skript%2C%20mit%20dem%20die%20Plattform%20standardm%C3%A4%C3%9Fig%20gestartet%20wird%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_6.png%22%20target%3D%22_blank%22%3E%3CIMG%20class%3D%22aligncenter%20size-full%20wp-image-13361%22%20alt%3D%22image_6%22%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Flegacyfs%2Fonline%2Fwp_images%2F2014%2F05%2Fimage_6.png%22%20width%3D%22420%22%20height%3D%22232%22%20%2F%3E%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fsupport.sas.com%2Fdemosdownloads%2Fdownarea_t4.jsp%3FproductID%3D114635%26amp%3Bjmpflag%3DN%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20Dieses%20Add-In%20%3C%2FA%3E%20ist%20neben%20vielen%20anderen%20auch%20auf%20der%20%3CA%20href%3D%22http%3A%2F%2Fsupport.sas.com%2Fdemosdownloads%2Fsysdep_t4.jsp%3FpackageID%3D000416%26amp%3Bjmpflag%3DY%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20JMP-Dateiaustausch%20%3C%2FA%3E%20.%20(F%C3%BCr%20den%20Zugriff%20ist%20ein%20kostenloses%20SAS-Profil%20erforderlich.)%3C%2FP%3E%3C%2FLINGO-BODY%3E
New contingency analysis add-in for JMP
A contingency analysis determines whether there is a relationship between two categorical variables. A caterer, for example, might be interested in knowing whether entrée selections at an event were related to gender, given the following data:
image_1
The contingency platform in JMP requires the X and Y variables to be contained in two columns, with the cell counts in a third:
image_2
With the “Contingency (Table Format)” add-in, developed especially for students and others who are new to JMP, you can launch a contingency analysis with data that is arranged in “crosstab” format, without having to stack the data first:
image_3
Simply specify the variables as shown here:
image_4
The add-in creates the contingency report and includes buttons that let you easily swap the rows and columns of the report if desired:
image_5
If the “Show New Table” option is selected, the add-in also generates a stacked table containing a script that will launch the platform in the standard manner:
image_6
This add-in, along with many others, is available on the JMP File Exchange. (A free SAS profile is needed for access.)
Article Labels
