Share your ideas for the JMP Scripting Unsession at Discovery Summit by September 17th. We hope to see you there!
New Distribution customizations & options in JMP 10
The Distribution platform, frequently the backbone of data exploration, is one of the most widely used platforms in JMP. The JMP 10 Distribution platform has additional customizations and options to make this phase of data exploration even more individualized and easier than before. This blog post will focus on the reports that are displayed by default in Distribution for continuous data.
Figure 1 shows the new default report in Distribution for continuous data when analyzing Sugars from the Cereal data found in Cereal.jmp in JMP's Sample Data folder.
This report should look very familiar. The most obvious difference is that the “Moments” report has been renamed the “Summary Statistics” report. On close examination, you can also see that there is a new submenu for the Summary Statistics report. Selecting “Customize Summary Statistics” from this submenu displays a dialog for customizing the Summary Statistics report. (Note that this menu item is also available under the Display Options menu, replacing the “More Moments” menu item.) This dialog allows the user to add or remove any statistic in the Summary Statistics report by checking or unchecking the appropriate boxes. Figure 2 shows this dialog with my summary statistics customizations.
Notice that many additional summary statistics have been added: N Zero, N Unique, Uncorrected SS, Corrected SS, Autocorrelation, Median, Mode, Trimmed Mean, Geometric Mean, Range, Interquartile Range, and Median Absolute Deviation. Figure 3 shows my customized summary statistics report. If Figure 3 displays the summary statistics I would prefer to see by default, I can alter the Distribution Summary Statistics preferences in JMP platform preferences to customize my default report.
In addition to the Summary Statistics customizations, the Quantile report can be customized as well. There is now a “Set Quantile Increment” menu item under Display Options for altering which quantiles are shown in the report. Figure 4 shows this dialog.
I chose to display deciles in my Quantile report by entering 0.1 as the increment. Figure 5 shows my customized Quantile report of deciles.
Look for my next blog post where I will discuss Distribution’s new Custom Quantiles menu item for even more quantile customizations and options.
Article Labels
Article Tags
11 Comments
Visitor
New Distribution options in JMP 10: Custom Quantiles wrote:
[...] previous blog post discussed two new options in the JMP 10 Distribution platform for customizing the summary [...]
Visitor
Homepage wrote:
... [Trackback]...
[...] Find More Informations here: blogs.sas.com/content/jmp/2012/03/14/new-distribution-customizations-options-in-jmp-10/ [...]...
Visitor
my homepage wrote:
... [Trackback]...
[...] Read More: blogs.sas.com/content/jmp/2012/03/14/new-distribution-customizations-options-in-jmp-10/ [...]...
Visitor
× × ×¡× ×¨ × × × × wrote:
... [Trackback]...
Visitor
clips wrote:
... [Trackback]...
[...] Read More here: blogs.sas.com/content/jmp/2012/03/14/new-distribution-customizations-options-in-jmp-10/ [...]...
Visitor
jimmynastic, reviews, phones, computers, technology wrote:
... [Trackback]...
[...] There you will find 76557 more Infos: blogs.sas.com/content/jmp/2012/03/14/new-distribution-customizations-options-in-jmp-10/ [...]...
Visitor
ecommerce web hosting wrote:
... [Trackback]...
[...] Informations on that Topic: blogs.sas.com/content/jmp/2012/03/14/new-distribution-customizations-options-in-jmp-10/ [...]...
Visitor
×¢× ×¦× × × × × × ×ª wrote:
... [Trackback]...
[...] Read More Infos here: blogs.sas.com/content/jmp/2012/03/14/new-distribution-customizations-options-in-jmp-10/ [...]...
Visitor
how to make a website wrote:
... [Trackback]...
Visitor
bjftysmpbn wrote:
Execellent post !...
Visitor
