%3CLINGO-SUB%20id%3D%22lingo-sub-30215%22%20slang%3D%22en-US%22%3ECreazione%20di%20modelli%20di%20report%20che%20si%20collegano%20alla%20grafica%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-30215%22%20slang%3D%22en-US%22%3E%3CP%3EI%20clienti%20ci%20chiedono%20spesso%20se%20%C3%A8%20possibile%20creare%20modelli%20di%20report%20che%20si%20apriranno%20automaticamente%20con%20i%20risultati%20delle%20analisi%20pi%C3%B9%20recenti%20eseguite%20in%20%3CA%20href%3D%22http%3A%2F%2Fjmp.com%2Fsoftware%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20JMP%20%3C%2FA%3E%20.%20Non%20solo%20%C3%A8%20possibile%2C%20%C3%A8%20molto%20pi%C3%B9%20facile%20di%20quanto%20pensi.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIn%20breve%2C%20ecco%20i%20passi%20da%20compiere%20per%20ottenere%20questo%20risultato%3A%3C%2FP%3E%3CP%3E%3COL%3E%3C%2FOL%3E%3C%2FP%3E%3CP%3E%3CLI%3ECrea%20l'output%20JMP%20che%20desideri.%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3ESalva%20le%20parti%20desiderate%20di%20questa%20uscita%20come%20file%20grafici.%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3EInserisci%20collegamenti%20a%20questi%20file%20grafici%20nei%20tuoi%20documenti%20di%20scelta%20(spesso%20Word%2C%20PowerPoint%2C%20Excel%2C%20ecc.).%3CSTRONG%3E%20Nota%3A%20%3C%2FSTRONG%3E%20Questa%20parte%20deve%20essere%20eseguita%20una%20sola%20volta.%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EQuesto%20%C3%A8%20tutto%20ci%C3%B2%20che%20%C3%A8%20richiesto%20-%20ma%20ti%20consigliamo%20di%20creare%20anche%20uno%20script%20per%20eseguire%20i%20primi%20due%20passaggi%3B%20in%20questo%20modo%2C%20l'aggiornamento%20del%20modello%20in%20un%20attimo%20sar%C3%A0%20un%20gioco%20da%20ragazzi.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUna%20volta%20creato%2C%20il%20documento%20si%20aprir%C3%A0%20con%20le%20versioni%20pi%C3%B9%20recenti%20dei%20file%20di%20output.%20Ogni%20volta%20che%20i%20dati%20cambiano%2C%20esegui%20i%20primi%20due%20passaggi%20sopra%20(o%20semplicemente%20esegui%20lo%20script).%20Questo%20produrr%C3%A0%20nuovi%20file%2C%20sovrascrivendo%20quelli%20vecchi.%20La%20prossima%20volta%20che%20aprirai%20il%20tuo%20documento%2C%20mostrer%C3%A0%20il%20contenuto%20dei%20nuovi%20file.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMolti%20dei%20nostri%20clienti%20adorano%20il%20suono%20di%20questo%2C%20ma%20hanno%20bisogno%20di%20un%20piccolo%20aiuto%20per%20iniziare.%20L'ho%20messo%20%3CA%20href%3D%22https%3A%2F%2Flogin.sas.com%2Fopensso%2FUI%2FLogin%3Frealm%3D%2Fextweb%26amp%3Bgoto%3Dhttp%3A%2F%2Fsupport.sas.com%2Fdemosdownloads%2Flicense.jsp%3FproductID%3D111668%26amp%3Bjmpflag%3DY%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20un%20semplice%20tutorial%20%3C%2FA%3E%20nella%20sezione%20%22Dati%20di%20esempio%22%20del%20%3CA%20href%3D%22http%3A%2F%2Fsupport.sas.com%2Fdemosdownloads%2Fsysdep_t4.jsp%3FpackageID%3D000416%26amp%3Bjmpflag%3DY%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20Scambio%20file%20JMP%20%3C%2FA%3E%20che%20ti%20guider%C3%A0%20attraverso%20il%20processo%20passo%20dopo%20passo.%20Dai%20un'occhiata%20e%20vedi%20cosa%20ti%20sei%20perso!%20(Il%20download%20del%20tutorial%20richiede%20un%20profilo%20SAS%20gratuito.)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32114%22%20slang%3D%22en-US%22%3EBrady%20Brady%20ha%20scritto%3A%20Questo%20sta%20accadendo%20perch%C3%A9%20la%20grafica%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32114%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Brady%20Brady%20%3C%2FSTRONG%3E%20ha%20scritto%3A%3C%2FP%3E%3CP%3ECi%C3%B2%20accade%20perch%C3%A9%20la%20grafica%20di%20tutti%20i%20file%20.pptx%20%C3%A8%20collegata%20allo%20stesso%20set%20di%20file%20.png%2C%20che%20vengono%20sovrascritti%20ogni%20volta%20che%20si%20esegue%20lo%20script%20in%20JMP.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDopo%20aver%20salvato%20l'ultimo%20file%20.pptx%20con%20un%20nome%20diverso%20da%20.pptx%2C%20sar%C3%A0%20necessario%20interrompere%20tutti%20i%20collegamenti%20ai%20file.%20Ci%20dovrebbe%20essere%20un'opzione%20in%20Power%20Point%20per%20farlo.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUn'altra%20idea%20che%20potrebbe%20funzionare%20per%20te%20%C3%A8%20stampare%20il%20file%20.pptx%20in%20un%20file%20.pdf.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESaluti%2C%3C%2FP%3E%3CP%3EBrady%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32113%22%20slang%3D%22en-US%22%3EMaira%20ha%20scritto%3A%20Ciao%20Brady%2C%20Bel%20lavoro%2C%20mi%20aiuta%20davvero%20come%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32113%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Maira%20%3C%2FSTRONG%3E%20ha%20scritto%3A%3C%2FP%3E%3CP%3ECiao%20Brady%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBel%20lavoro%2C%20mi%20aiuta%20davvero%20come%20sono%20ancora%20nuovo%20su%20questo%20argomento.%20Sono%20riuscito%20a%20creare%20un%20sistema%20di%20automazione%20per%20il%20mio%20team%20che%20%C3%A8%20in%20grado%20di%20aggiornare%20automaticamente%20i%20grafici%20in%20JMP%20a%20Power%20Point.%20Ho%20anche%20fornito%20un%20nome%20di%20modello%20Power%20Point%20come%20%22template.pptx%22%2C%20in%20modo%20che%2C%20una%20volta%20eseguito%20lo%20script%2C%20il%20grafico%20pi%C3%B9%20recente%20venga%20aggiornato%20automaticamente%20in%20questo%20modello.%20Quindi%2C%20il%20mio%20team%20deve%20solo%20salvare%20come%20%22template.pptx%22%20con%20nome%20specifico%20e%20memorizzare%20nella%20cartella%20specifica.%20Ma%20il%20problema%20%C3%A8%20quando%20lo%20script%20viene%20eseguito%2C%20tutti%20i%20precedenti%20file%20Power%20Point%20vengono%20aggiornati%20con%20l'ultimo%20grafico.%20Come%20posso%20impostare%20solo%20%22template.pptx%22%20sono%20aggiornati%20con%20il%20grafico%20pi%C3%B9%20recente%20non%20il%20salvataggio%20come%20%22template.pptx%22%20che%20salvo%20con%20nome%20diverso.%20%C3%88%20possibile%3F%20Grazie.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32112%22%20slang%3D%22en-US%22%3EMartin%20Kane%20ha%20scritto%3A%20Sono%20abbastanza%20sicuro%20che%20potresti%20correre%20un%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32112%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Martin%20Kane%20%3C%2FSTRONG%3E%20ha%20scritto%3A%3C%2FP%3E%3CP%3ESono%20abbastanza%20sicuro%20che%20potresti%20eseguire%20una%20macro%20in%20ppt%20che%20aggiorna%20la%20grafica%20ogni%20periodo%20(ad%20esempio%20minuto).%20L'ho%20usato%20per%20ideare%20l'utilizzo%20di%20R%20per%20eseguire%20un'analisi%20e%20aggiornare%20la%20grafica%20in%20ppt%2C%20il%20tutto%20durante%20l'esecuzione%20in%20modalit%C3%A0%20presentazione.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32111%22%20slang%3D%22en-US%22%3EBrady%20Brady%20ha%20scritto%3A%20ciao%20Charlie%2C%20non%20sono%20sicuro%20se%20questo%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32111%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Brady%20Brady%20%3C%2FSTRONG%3E%20ha%20scritto%3A%3C%2FP%3E%3CP%3ECiao%20Charlie%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENon%20sono%20sicuro%20che%20sia%20possibile.%20%C3%88%20a%20mia%20conoscenza%20che%20quando%20Powerpoint%20si%20apre%2C%20guarda%20i%20collegamenti%20e%20carica%20i%20file%20che%20si%20trovano%20in%20questi%20luoghi%20in%20quel%20momento%2C%20e%20non%20tiene%20traccia%20di%20se%20questi%20file%20sono%20stati%20modificati.%20Forse%20c'%C3%A8%20una%20soluzione%20per%20questo%2C%20ma%20sfortunatamente%20non%20ne%20sono%20a%20conoscenza.%20Ho%20cercato%20un%20po%20'su%20Google%2C%20ma%20non%20sono%20riuscito%20a%20trovare%20nulla%20che%20mi%20aiutasse.%20Scusate!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESaluti%2C%3C%2FP%3E%3CP%3EBrady%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32110%22%20slang%3D%22en-US%22%3ECharles%20Fields%20ha%20scritto%3A%20Great%20post!%20Molto%20utile.%20Per%20spingerlo%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32110%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Charles%20Fields%20%3C%2FSTRONG%3E%20ha%20scritto%3A%3C%2FP%3E%3CP%3EOttimo%20post!%20Molto%20utile.%3C%2FP%3E%3CP%3EPer%20spingerlo%20un%20po%20'oltre%2C%20mi%20piacerebbe%20avere%20una%20presentazione%20di%20PowerPoint%20in%20esecuzione%20in%20modalit%C3%A0%20presentazione%2C%20che%20va%20fuori%20e%20prende%20un%20file%20jpeg%20o%20png%20aggiornato%20in%20una%20directory%20specifica.%3C%2FP%3E%3CP%3EAbbiamo%20alcune%20routine%20di%20controllo%20della%20trama%20che%20catturano%20i%20dati%20aggiornati%20ogni%20minuto%20e%20le%20uscite%3C%2FP%3E%3CP%3Egrafici%20di%20controllo%20freschi%20in%20formato%20jpeg.%20Vorremmo%20che%20il%20PPT%20funzionasse%20continuamente%20e%20aggiorni%20il%3C%2FP%3E%3CP%3Ejpeg%20automaticamente%20senza%20dover%20riaprire%20il%20file%20PPT%20ogni%20volta.%3C%2FP%3E%3CP%3E%C3%88%20possibile%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EGrazie%2C%3C%2FP%3E%3CP%3ECharlie%20Fields%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32109%22%20slang%3D%22en-US%22%3EErica%20ha%20scritto%3A%20Desidera%20semplicemente%20dire%20che%20il%20tuo%20articolo%20%C3%A8%20come%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32109%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Erica%20%3C%2FSTRONG%3E%20ha%20scritto%3A%3C%2FP%3E%3CP%3EDesidera%20semplicemente%20dire%20che%20il%20tuo%20articolo%20%C3%A8%20fantastico.%20La%20chiarezza%20nel%20tuo%20post%20%C3%A8%20semplicemente%20fantastica%20e%20potrei%20pensare%20che%20tu%20sia%20un%20esperto%20in%20materia.%20Bene%20con%20la%20tua%20autorizzazione%20permettimi%20di%20prendere%20il%20tuo%20feed%20RSS%20per%20tenerti%20aggiornato%20con%20i%20prossimi%20post.%20Grazie%20mille%20e%20per%20favore%20continua%20il%20lavoro%20gratificante.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32108%22%20slang%3D%22en-US%22%3EBrady%20Brady%20ha%20scritto%3A%20Se%20non%20ti%20dispiace%20creare%20un%20nuovo%20tavolo%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32108%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Brady%20Brady%20%3C%2FSTRONG%3E%20ha%20scritto%3A%3C%2FP%3E%3CP%3ESe%20non%20ti%20dispiace%20creare%20una%20nuova%20tabella%2C%20il%20modo%20pi%C3%B9%20semplice%20per%20farlo%20%C3%A8%20con%20la%20piattaforma%20%22Join%22.%20Assicurati%20di%20selezionare%20l'opzione%20%22Aggiorna%20tabella%20principale%20...%22%2C%20oltre%20alle%20funzioni%20%22Includi%20non%20corrispondenti%22.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESe%20devi%20evitare%20di%20creare%20una%20nuova%20tabella%2C%20puoi%20fare%20qualcosa%20di%20simile%20al%20seguente%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%20aggiorna%20la%20vecchia%20tabella%20con%20le%20informazioni%20nella%20nuova%20tabella%2C%20usando%20%22Aggiorna%22%3C%2FP%3E%3CP%3E2.%20seleziona%20le%20righe%20nella%20nuova%20tabella%20con%20gli%20ID%20che%20non%20sono%20presenti%20nella%20vecchia%20tabella%3C%2FP%3E%3CP%3E3.%20separare%20queste%20righe%20come%20una%20tabella%20invisibile%20e%20concatenarle%20alla%20'vecchia'%20tabella%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32107%22%20slang%3D%22en-US%22%3ERon%20Horne%20ha%20scritto%3A%20Grazie%20per%20il%20grande%20contributo%2C%20ero%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32107%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Ron%20Horne%20%3C%2FSTRONG%3E%20ha%20scritto%3A%3C%2FP%3E%3CP%3EGrazie%20per%20l'ottimo%20contributo%2C%20in%20realt%C3%A0%20stavo%20cercando%20qualcosa%20di%20simile%20per%20un%20po%20'.%3C%2FP%3E%3CP%3EConsentimi%20una%20domanda%20successiva%20nella%20stessa%20cornice%20mentale.%20Prima%20di%20aggiornare%20il%20mio%20rapporto%20ho%20bisogno%20di%20aggiornare%20la%20mia%20tabella.%20using%20Tables%20%26gt%3B%26gt%3B%20update%20non%20fa%20il%20lavoro%20per%20me%20poich%C3%A9%20aggiorna%20solo%20le%20osservazioni%20esistenti%20e%20non%20ne%20aggiunge%20di%20nuove%20dal%20nuovo%20set%20di%20dati.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Making report templates that link to JMP graphics
Customers often ask us whether it is possible to create report templates that will automatically open with the results of the most recent analyses performed in JMP. Not only is this possible, it is most likely easier than you think.
Briefly, here are the steps that must be taken to accomplish this:
  1. Create the JMP output you want.
  2. Save the desired portions of this output as graphics files.
  3. Insert links to these graphics files into your document(s) of choice (often Word, PowerPoint, Excel, etc.). Note: This part only has to be done once.
  4. This is all that is required — but we recommend that you also create a script to perform the first two steps; this way, updating the template on a moment’s notice will be a snap.
    Once created, the document will open with the most recent versions of the output files. Any time the data changes, perform the first two steps above (or simply run the script). This will output new files, overwriting the old ones. The next time you open your document, it will show the contents of the new files.
    Many of our customers love the sound of this, but need a little help getting started. I’ve placed a simple tutorial in the “Sample Data” section of the JMP File Exchange that will lead you through the process step by step. Take a look, and see what you’ve been missing! (Download of tutorial requires a free SAS profile.)
    Article Labels
    8 Comments
