%3CLINGO-SUB%20id%3D%22lingo-sub-30215%22%20slang%3D%22en-US%22%3ERealizaci%C3%B3n%20de%20plantillas%20de%20informes%20que%20enlazan%20a%20gr%C3%A1ficos%20JMP.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-30215%22%20slang%3D%22en-US%22%3E%3CP%3ELos%20clientes%20a%20menudo%20nos%20preguntan%20si%20es%20posible%20crear%20plantillas%20de%20informes%20que%20se%20abrir%C3%A1n%20autom%C3%A1ticamente%20con%20los%20resultados%20de%20los%20an%C3%A1lisis%20m%C3%A1s%20recientes%20realizados%20en%20%3CA%20href%3D%22http%3A%2F%2Fjmp.com%2Fsoftware%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20JMP%20%3C%2FA%3E%20.%20No%20solo%20es%20posible%2C%20es%20m%C3%A1s%20f%C3%A1cil%20de%20lo%20que%20piensas.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBrevemente%2C%20aqu%C3%AD%20est%C3%A1n%20los%20pasos%20que%20se%20deben%20tomar%20para%20lograr%20esto%3A%3C%2FP%3E%3CP%3E%3COL%3E%3C%2FOL%3E%3C%2FP%3E%3CP%3E%3CLI%3ECrea%20la%20salida%20JMP%20que%20quieras.%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3EGuarde%20las%20porciones%20deseadas%20de%20esta%20salida%20como%20archivos%20gr%C3%A1ficos.%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3CLI%3EInserte%20enlaces%20a%20estos%20archivos%20de%20gr%C3%A1ficos%20en%20sus%20documentos%20de%20elecci%C3%B3n%20(a%20menudo%20Word%2C%20PowerPoint%2C%20Excel%2C%20etc.).%3CSTRONG%3E%20Nota%3A%20%3C%2FSTRONG%3E%20Esta%20parte%20solo%20tiene%20que%20hacerse%20una%20vez.%3C%2FLI%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EEsto%20es%20todo%20lo%20que%20se%20requiere%2C%20pero%20le%20recomendamos%20que%20tambi%C3%A9n%20cree%20un%20script%20para%20realizar%20los%20dos%20primeros%20pasos%3B%20De%20esta%20manera%2C%20actualizar%20la%20plantilla%20en%20cualquier%20momento%20ser%C3%A1%20muy%20sencillo.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUna%20vez%20creado%2C%20el%20documento%20se%20abrir%C3%A1%20con%20las%20versiones%20m%C3%A1s%20recientes%20de%20los%20archivos%20de%20salida.%20Siempre%20que%20cambien%20los%20datos%2C%20realice%20los%20dos%20primeros%20pasos%20anteriores%20(o%20simplemente%20ejecute%20el%20script).%20Esto%20generar%C3%A1%20nuevos%20archivos%2C%20sobrescribiendo%20los%20antiguos.%20La%20pr%C3%B3xima%20vez%20que%20abra%20su%20documento%2C%20se%20mostrar%C3%A1%20el%20contenido%20de%20los%20nuevos%20archivos.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMuchos%20de%20nuestros%20clientes%20aman%20el%20sonido%20de%20esto%2C%20pero%20necesitan%20un%20poco%20de%20ayuda%20para%20comenzar.%20He%20colocado%20%3CA%20href%3D%22https%3A%2F%2Flogin.sas.com%2Fopensso%2FUI%2FLogin%3Frealm%3D%2Fextweb%26amp%3Bgoto%3Dhttp%3A%2F%2Fsupport.sas.com%2Fdemosdownloads%2Flicense.jsp%3FproductID%3D111668%26amp%3Bjmpflag%3DY%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20un%20tutorial%20simple%20%3C%2FA%3E%20en%20la%20secci%C3%B3n%20%E2%80%9CDatos%20de%20muestra%E2%80%9D%20del%20%3CA%20href%3D%22http%3A%2F%2Fsupport.sas.com%2Fdemosdownloads%2Fsysdep_t4.jsp%3FpackageID%3D000416%26amp%3Bjmpflag%3DY%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20Intercambio%20de%20archivos%20JMP%20%3C%2FA%3E%20Eso%20te%20llevar%C3%A1%20a%20trav%C3%A9s%20del%20proceso%20paso%20a%20paso.%20%C2%A1Echa%20un%20vistazo%20y%20mira%20lo%20que%20te%20has%20estado%20perdiendo!%20(La%20descarga%20del%20tutorial%20requiere%20un%20perfil%20SAS%20gratuito).%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32114%22%20slang%3D%22en-US%22%3EBrady%20Brady%20escribi%C3%B3%3A%20Esto%20est%C3%A1%20sucediendo%20porque%20los%20gr%C3%A1ficos%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32114%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Brady%20Brady%20%3C%2FSTRONG%3E%20escribi%C3%B3%3A%3C%2FP%3E%3CP%3EEsto%20sucede%20porque%20los%20gr%C3%A1ficos%20en%20todos%20los%20archivos%20.pptx%20est%C3%A1n%20vinculados%20al%20mismo%20conjunto%20de%20archivos%20.png%2C%20que%20se%20sobrescriben%20cada%20vez%20que%20se%20ejecuta%20el%20script%20en%20JMP.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUna%20vez%20que%20haya%20guardado%20el%20%C3%BAltimo%20archivo%20.pptx%20con%20un%20nombre%20diferente%20al%20de%20.pptx%2C%20deber%C3%A1%20romper%20todos%20los%20enlaces%20a%20los%20archivos.%20Deber%C3%ADa%20haber%20una%20opci%C3%B3n%20en%20Power%20Point%20para%20hacer%20esto.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EOtra%20idea%20que%20podr%C3%ADa%20funcionar%20para%20usted%20es%20imprimir%20el%20archivo%20.pptx%20en%20un%20archivo%20.pdf.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAclamaciones%2C%3C%2FP%3E%3CP%3EBrady%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32113%22%20slang%3D%22en-US%22%3EMaira%20escribi%C3%B3%3A%20Hola%20Brady%2C%20buen%20trabajo%2C%20realmente%20me%20ayuda%20como%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32113%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Maira%20%3C%2FSTRONG%3E%20escribi%C3%B3%3A%3C%2FP%3E%3CP%3EHola%20brady%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBuen%20trabajo%2C%20realmente%20me%20ayud%C3%B3%2C%20ya%20que%20todav%C3%ADa%20soy%20nuevo%20en%20este%20tema.%20Logr%C3%A9%20crear%20un%20sistema%20de%20automatizaci%C3%B3n%20para%20mi%20equipo%20que%20puede%20actualizar%20autom%C3%A1ticamente%20los%20gr%C3%A1ficos%20en%20JMP%20a%20Power%20Point.%20Tambi%C3%A9n%20proporcion%C3%A9%20un%20nombre%20de%20plantilla%20de%20Power%20Point%20como%20%22template.pptx%22%2C%20de%20modo%20que%20una%20vez%20que%20se%20ejecute%20el%20script%2C%20el%20%C3%BAltimo%20gr%C3%A1fico%20se%20actualizar%C3%A1%20autom%C3%A1ticamente%20en%20esta%20plantilla.%20Entonces%2C%20mi%20equipo%20solo%20necesita%20guardar%20como%20%22template.pptx%22%20con%20un%20nombre%20espec%C3%ADfico%20y%20almacenar%20en%20una%20carpeta%20espec%C3%ADfica.%20Pero%20el%20problema%20es%20que%20cuando%20se%20ejecuta%20el%20script%2C%20todos%20los%20archivos%20anteriores%20de%20Power%20Point%20tambi%C3%A9n%20se%20actualizan%20con%20el%20%C3%BAltimo%20gr%C3%A1fico.%20%C2%BFC%C3%B3mo%20puedo%20establecer%20que%20solo%20%22template.pptx%22%20se%20actualice%20con%20el%20%C3%BAltimo%20gr%C3%A1fico%2C%20no%20como%20%22template.pptx%22%20que%20guardo%20con%20un%20nombre%20diferente%3F%20es%20posible%3F%20Gracias.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32112%22%20slang%3D%22en-US%22%3EMartin%20Kane%20escribi%C3%B3%3A%20Estoy%20bastante%20seguro%20de%20que%20podr%C3%ADas%20correr%20un%20m%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32112%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Martin%20Kane%20%3C%2FSTRONG%3E%20escribi%C3%B3%3A%3C%2FP%3E%3CP%3EEstoy%20bastante%20seguro%20de%20que%20podr%C3%ADa%20ejecutar%20una%20macro%20en%20ppt%20que%20actualice%20los%20gr%C3%A1ficos%20en%20cada%20per%C3%ADodo%20(por%20ejemplo%2C%20minutos).%20He%20usado%20esto%20con%20la%20idea%20de%20usar%20R%20para%20ejecutar%20un%20an%C3%A1lisis%20y%20actualizar%20los%20gr%C3%A1ficos%20en%20ppt%2C%20todo%20mientras%20se%20ejecuta%20en%20modo%20de%20presentaci%C3%B3n.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32111%22%20slang%3D%22en-US%22%3EBrady%20Brady%20escribi%C3%B3%3A%20Hola%20Charlie%2C%20no%20estoy%20seguro%20de%20si%20esto%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32111%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Brady%20Brady%20%3C%2FSTRONG%3E%20escribi%C3%B3%3A%3C%2FP%3E%3CP%3EHola%20charlie%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENo%20estoy%20seguro%20de%20si%20esto%20es%20posible.%20Tengo%20entendido%20que%20cuando%20se%20abre%20Powerpoint%2C%20mira%20los%20enlaces%20y%20carga%20los%20archivos%20que%20se%20encuentran%20en%20estas%20ubicaciones%20en%20ese%20momento%2C%20y%20no%20hace%20un%20seguimiento%20de%20si%20estos%20archivos%20han%20cambiado.%20Quiz%C3%A1s%20haya%20una%20soluci%C3%B3n%20para%20esto%2C%20pero%20desafortunadamente%20no%20conozco%20una.%20Busqu%C3%A9%20en%20Google%20un%20poco%2C%20pero%20no%20pude%20encontrar%20nada%20que%20ayudara%20con%20esto.%20%C2%A1Lo%20siento!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAclamaciones%2C%3C%2FP%3E%3CP%3EBrady%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32110%22%20slang%3D%22en-US%22%3ECharles%20Fields%20escribi%C3%B3%3A%20%C2%A1Gran%20publicaci%C3%B3n!%20Muy%20%C3%BAtil.%20Para%20empujarlo%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32110%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Campos%20de%20charles%20%3C%2FSTRONG%3E%20escribi%C3%B3%3A%3C%2FP%3E%3CP%3E%C2%A1Buena%20publicaci%C3%B3n!%20Muy%20%C3%BAtil.%3C%2FP%3E%3CP%3EPara%20llevarlo%20un%20poco%20m%C3%A1s%20lejos%2C%20me%20gustar%C3%ADa%20tener%20una%20presentaci%C3%B3n%20de%20PowerPoint%20que%20se%20ejecute%20en%20modo%20de%20presentaci%C3%B3n%20de%20diapositivas%2C%20que%20salga%20y%20capture%20un%20archivo%20jpeg%20o%20png%20actualizado%20en%20un%20directorio%20espec%C3%ADfico.%3C%2FP%3E%3CP%3ETenemos%20algunas%20rutinas%20de%20gr%C3%A1ficos%20de%20control%20que%20recopilan%20datos%20actualizados%20cada%20minuto%20y%20salidas%3C%2FP%3E%3CP%3ENuevos%20cuadros%20de%20control%20en%20formato%20jpeg.%20Nos%20gustar%C3%ADa%20que%20PPT%20se%20ejecute%20continuamente%20y%20actualice%20el%3C%2FP%3E%3CP%3Ejpegs%20autom%C3%A1ticamente%20sin%20tener%20que%20volver%20a%20abrir%20el%20archivo%20PPT%20cada%20vez.%3C%2FP%3E%3CP%3Ees%20posible%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EGracias%2C%3C%2FP%3E%3CP%3ECharlie%20Fields%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32109%22%20slang%3D%22en-US%22%3EErica%20escribi%C3%B3%3A%20Simplemente%20quiero%20decir%20que%20tu%20art%C3%ADculo%20es%20tan%20sorprendente%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32109%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Erica%20%3C%2FSTRONG%3E%20escribi%C3%B3%3A%3C%2FP%3E%3CP%3ESimplemente%20quiero%20decir%20que%20su%20art%C3%ADculo%20es%20tan%20incre%C3%ADble.%20La%20claridad%20en%20tu%20publicaci%C3%B3n%20es%20simplemente%20genial%20y%20puedo%20asumir%20que%20eres%20un%20experto%20en%20este%20tema.%20Bien%2C%20con%20su%20permiso%2C%20perm%C3%ADtame%20obtener%20su%20feed%20RSS%20para%20estar%20actualizado%20con%20la%20pr%C3%B3xima%20publicaci%C3%B3n.%20Gracias%20un%20mill%C3%B3n%20y%20por%20favor%20sigan%20con%20el%20trabajo%20gratificante.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32108%22%20slang%3D%22en-US%22%3EBrady%20Brady%20escribi%C3%B3%3A%20Si%20no%20te%20importa%20crear%20una%20nueva%20tabla%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32108%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Brady%20Brady%20%3C%2FSTRONG%3E%20escribi%C3%B3%3A%3C%2FP%3E%3CP%3ESi%20no%20le%20importa%20crear%20una%20nueva%20tabla%2C%20la%20forma%20m%C3%A1s%20sencilla%20de%20hacerlo%20es%20con%20la%20plataforma%20%22Unirse%22.%20Aseg%C3%BArese%20de%20seleccionar%20la%20opci%C3%B3n%20%22Actualizar%20tabla%20principal%20...%22%2C%20as%C3%AD%20como%20las%20funciones%20%22Incluir%20no%20coincidentes%22.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESi%20debe%20evitar%20crear%20una%20nueva%20tabla%2C%20podr%C3%ADa%20hacer%20algo%20como%20lo%20siguiente%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%20actualice%20la%20tabla%20anterior%20con%20la%20informaci%C3%B3n%20en%20la%20tabla%20nueva%2C%20usando%20%22Actualizar%22%3C%2FP%3E%3CP%3E2.%20seleccione%20las%20filas%20en%20la%20nueva%20tabla%20que%20tienen%20ID%20que%20no%20est%C3%A1n%20presentes%20en%20la%20tabla%20anterior%3C%2FP%3E%3CP%3E3.%20subcontrata%20estas%20filas%20como%20una%20tabla%20invisible%20y%20concat%C3%A9nalas%20a%20la%20tabla%20'antigua'%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-32107%22%20slang%3D%22en-US%22%3ERon%20Horne%20escribi%C3%B3%3A%20Gracias%20por%20la%20gran%20contribuci%C3%B3n%2C%20estaba%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-32107%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20Ron%20Horne%20%3C%2FSTRONG%3E%20escribi%C3%B3%3A%3C%2FP%3E%3CP%3EGracias%20por%20la%20gran%20contribuci%C3%B3n%2C%20en%20realidad%20estaba%20buscando%20algo%20como%20esto%20por%20un%20tiempo.%3C%2FP%3E%3CP%3EPerm%C3%ADtame%20una%20pregunta%20de%20seguimiento%20en%20el%20mismo%20marco%20mental.%20Antes%20de%20actualizar%20mi%20informe%20necesito%20actualizar%20mi%20tabla.%20el%20uso%20de%20Tablas%20%26gt%3B%26gt%3B%20actualizaci%C3%B3n%20no%20hace%20el%20trabajo%20por%20m%C3%AD%2C%20ya%20que%20solo%20actualiza%20las%20observaciones%20existentes%20y%20no%20agrega%20nuevas%20del%20conjunto%20de%20datos%20nuevo.%3C%2FP%3E%3C%2FLINGO-BODY%3E
Making report templates that link to JMP graphics
Customers often ask us whether it is possible to create report templates that will automatically open with the results of the most recent analyses performed in JMP. Not only is this possible, it is most likely easier than you think.
Briefly, here are the steps that must be taken to accomplish this:
  1. Create the JMP output you want.
  2. Save the desired portions of this output as graphics files.
  3. Insert links to these graphics files into your document(s) of choice (often Word, PowerPoint, Excel, etc.). Note: This part only has to be done once.
  4. This is all that is required — but we recommend that you also create a script to perform the first two steps; this way, updating the template on a moment’s notice will be a snap.
    Once created, the document will open with the most recent versions of the output files. Any time the data changes, perform the first two steps above (or simply run the script). This will output new files, overwriting the old ones. The next time you open your document, it will show the contents of the new files.
    Many of our customers love the sound of this, but need a little help getting started. I’ve placed a simple tutorial in the “Sample Data” section of the JMP File Exchange that will lead you through the process step by step. Take a look, and see what you’ve been missing! (Download of tutorial requires a free SAS profile.)
    Article Labels
    8 Comments
