%3CLINGO-SUB%20id%3D%22lingo-sub-29637%22%20slang%3D%22en-US%22%3EI%20'Heart'%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-29637%22%20slang%3D%22en-US%22%3E%3CP%3E%3CIMG%20class%3D%22alignright%22%20style%3D%22border%3A%200px%3B%20padding-left%3A%205px%3B%20padding-right%3A%205px%3B%22%20src%3D%22http%3A%2F%2Fblogs.sas.com%2Fjmp%2Fuploads%2Fvalentineplot2.GIF%22%20alt%3D%22%22%20width%3D%22251%22%20height%3D%22264%22%20%2F%3E%3C%2FP%3E%3CP%3ENon%20sono%20n%C3%A9%20uno%20statistico%20n%C3%A9%20un%20artista.%20Ma%20questo%20cuore%20che%20ho%20creato%20in%20JMP%20con%20i%20dati%20inventati%20%C3%A8%20carino%2C%20se%20posso%20dirlo%20anch'io.%20Lo%20scatterplot%20mostra%20il%20numero%20di%20baci%20per%20il%20numero%20di%20abbracci.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENon%20%C3%A8%20assolutamente%20perfetto%2C%20ma%20%C3%A8%20abbastanza%20simmetrico.%20L'ho%20spedito%20come%20un%20geniale%20geeky%20per%20la%20famiglia%20e%20gli%20amici.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMentre%20stavo%20regolando%20le%20coordinate%20del%20cuore%20(per%20esempio%2C%206%2C5%20abbracci%20e%2016.25%20baci)%2C%20ho%20dovuto%20chiedermi%3A%20c'%C3%A8%20un%20abbraccio%20o%20un%20quarto%20di%20bacio%3F%20Ho%20deciso%20che%20la%20risposta%20%C3%A8%20s%C3%AC%2C%20perch%C3%A9%20potresti%20abbracciare%20qualcuno%20con%20un%20braccio%20solo%20e%20il%20bacio%20dell'aria%20di%20Hollywood%20%C3%A8%20a%20malapena%20un%20bacio.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENaturalmente%2C%20questo%20non%20%C3%A8%20ci%C3%B2%20che%20JMP%20%C3%A8%20per.%20Ma%20devo%20dire%20che%20%C3%A8%20divertente%20giocare%20con%20il%20software%2C%20anche%20per%20un%20principiante%20come%20me.%20Ho%20appena%20iniziato%20a%20imparare%20JMP%20ed%20%C3%A8%20stato%20facile%20esplorare%20dopo%20aver%20preso%20il%20webcast%20live%20di%20un'ora%20(e%20gratuito)%2C%20%3CA%20href%3D%22http%3A%2F%2Fwww.jmp.com%2Fabout%2Fevents%2Fwebcasts%2Fget_jmp_start.shtml%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20Ottenere%20un%20inizio%20JMP.%20%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPuoi%20%3CA%20href%3D%22http%3A%2F%2Fwww.sas.com%2Fapps%2Fdemosdownloads%2FjmpSubmittedFE_PROD__downarea.jsp%3FproductID%3D108763%26amp%3Bjmpflag%3DY%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%22%3E%20scarica%20la%20mia%20tabella%20di%20dati%20%3C%2FA%3E%20con%20script%20scatterplot%20e%20due%20script%20di%20trama%20bubble%20-%20che%20%22disegnano%22%20il%20cuore%20in%20due%20modi%20aggiungendo%20tempo%20nel%20mix%20-%20e%20vediamo%20se%20riesci%20a%20migliorare%20il%20mio%20cuore.%20Oppure%2C%20perch%C3%A9%20non%20contribuire%20con%20i%20tuoi%20divertenti%20utilizzi%20di%20JMP%20al%20nostro%20%3CA%20href%3D%22http%3A%2F%2Fwww.sas.com%2Fapps%2Fdemosdownloads%2FjmpFileExchange_PROD__sysdep.jsp%3FpackageID%3D000416%26amp%3Bjmpflag%3DY%22%20rel%3D%22noopener%20noreferrer%22%20target%3D%22_blank%22%3E%20Scambio%20di%20file%20%3C%2FA%3E%20%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBuon%20San%20Valentino!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-31301%22%20slang%3D%22en-US%22%3EFan%20JMP%20ha%20scritto%3A%20Molti%20lavoratori%20hanno%20ipotizzato%20e%20ipotetico%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-31301%22%20slang%3D%22en-US%22%3E%3CP%3E%3CSTRONG%3E%20JMP%20Fan%20%3C%2FSTRONG%3E%20ha%20scritto%3A%3C%2FP%3E%3CP%3EMolti%20lavoratori%20hanno%20ipotizzato%20e%20ipotizzato%20la%20relazione%20tra%20abbracci%20e%20baci%20e%20se%20i%20due%20siano%2C%20o%20meno%2C%20correlati%20o%20meno%3B%20o%20-%20come%20spesso%20sembrano%20essere%20-%20un%20insieme%20di%20processi%20rigorosamente%20stocastici%20e%20casuali%20regolati%20principalmente%20dal%20caos%20e%20dalla%20birra.%20Guardando%20un%20po%20'pi%C3%B9%20attentamente%20al%20modello%20JMP%20dell'autore%2C%20%C3%A8%20evidente%20che%20ci%20sono%2C%20in%20effetti%2C%20pi%C3%B9%20esiti%20possibili%20per%20ogni%20occorrenza%20di%20un%20bacio%20e%20che%20non%20esiste%20una%20correlazione%20chiara%20che%20uno%20conduce%20necessariamente%20all'altro.%20Eri%20la%20persona%20fortunata%20a%20ricevere%20o%20dare%2015%20baci%2C%20la%20funzione%20rivela%20zero%20abbracci%20in%20cambio%20...%20o%20sei.%20Questo%20risultato%20%C3%A8%20indeterminato%20e%20altamente%20insoddisfacente%20se%20non%20addirittura%20inelegante%2C%20ma%20comune%20con%20i%20cicloidi%2C%20data%20la%20loro%20natura%20multivalore.%20Se%20uno%20desiderava%20ottimizzare%20gli%20abbracci%20e%20cercare%20i%20massimi%20locali%20della%20funzione%20cicloidale%20Hug-Kiss%20(HKCF)%2C%2010%20o%2020%20baci%20%C3%A8%20la%20variabile%20indipendente%20che%20ha%20pi%C3%B9%20probabilit%C3%A0%20di%20ottenere%20un%20massimo%20di%20solo%208%20abbracci%20o%20forse%20solo%202%20.%20Come%20riportato%20aneddoticamente%20da%20alcuni%20lavoratori%2C%20tuttavia%2C%20la%20funzione%20grafica%20riflette%20il%20comportamento%20segnalato%20e%2C%20sorprendentemente%2C%20ma%20non%20sorprendentemente%2C%20non%20%C3%A8%20prevista%20alcuna%20pianificazione%20qui%20e%20si%20ottiene%20ci%C3%B2%20che%20si%20ottiene%20come%20mostrato%20in%20modo%20cos%C3%AC%20chiaro%20nel%20modello%20dell'autore.%20Altri%20lavoratori%20hanno%20suggerito%20una%20correlazione%20positiva%20con%20l'assunzione%20di%20birra%20e%20molto%20probabilmente%20%22quanti%20minuti%20alla%20chiusura%22%20per%20essere%20anche%20fattori%20del%20primo%20ordine%20nel%20determinare%20l'ottimizzazione%20dell'abbraccio%2C%20che%20non%20sembrano%20essere%20considerati%20nella%20visualizzazione%20dell'autore.%3C%2FP%3E%3CP%3EDi%20significato%20(e%20una%20possibile%20area%20per%20pi%C3%B9%20lavoro)%2C%20%C3%A8%20il%20modello%20dell'autore%20che%20illustra%20che%20pi%C3%B9%20di%2025%20baci%20non%20portano%20ad%20alcun%20abbraccio%3B%20e%20meno%20di%205%20baci%20non%20ti%20abbraccia%20neanche.%20Anche%20se%20deludente%2C%20questo%20%C3%A8%20certamente%20comprensibile%20e%20si%20potrebbe%20concludere%20che%20essere%20%22sotto%22%20o%20%22sopra%22%20baciato%20ha%20il%20suo%20insieme%20di%20problemi%20che%20portano%20a%20una%20funzione%20non%20responsiva%2C%20piuttosto%20aberrante%2C%20%22vuota%22%20priva%20di%20qualsiasi%20abbraccio.%20Estendendo%20il%20modello%20dell'autore%2C%20proponiamo%20che%20queste%20aree%20di%20confine%20siano%20semplicemente%20inesplorate%20e%20necessitino%20di%20ulteriore%20lavoro%20e%20definizione.%20Data%20la%20relativa%20scarsit%C3%A0%20di%20dati%20e%20lavoratori%20che%20riferiscono%20su%20queste%20aree%20di%20frontiera%20non%20lavorate%20(K%20%26lt%3B5%20e%20K%26gt%3B%2025)%2C%20sono%20necessari%20ulteriori%20studi%20per%20-%20in%20primo%20luogo%20-%20pi%C3%B9%20chiaramente%20e%20accuratamente%20empirizzare%20e%20convalidare%20la%20funzione%20proposta%20esistente%3B%20ma%20anche%2C%20osservare%20e%20descrivere%20quali%20relazioni%20potenziali%20esistono%20in%20queste%20aree%20sconosciute.%20Esistono%20superfici%20Riemann%20multivalore%20con%20altre%20dimensioni%20(da%20minuti%20a%20chiusura%2C%20consumo%20di%20birra)%20in%20gioco%20in%20questo%20spazio%3F%20Oppure%2C%20come%20mostrato%20dall'autore%2C%20la%20relazione%20tra%20baci%20e%20abbracci%20%C3%A8%20strettamente%20una%20funzione%20multivalore%20bidimensionale%20non%20complessa%3F%20Le%20superfici%20di%20Riemann%20hanno%20certamente%20il%20potenziale%20per%20estendere%20e%20definire%20ulteriormente%20il%20modello%20HKCF%20attualmente%20proposto.%20%C3%88%20necessario%20pi%C3%B9%20lavoro%20per%20convalidare%20questa%20ipotesi.%20Questo%20nuovo%20modello%20HKCF%20%C3%A8%20certamente%20un%20primo%20inizio%20pionieristico%20e%20fornir%C3%A0%20una%20solida%20base%20su%20cui%20estendere%20ulteriori%20studi.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
I ‘Heart’ JMP
I am neither a statistician nor an artist. But this heart I created in JMP with made-up data is cute, if I may say so myself. The scatterplot shows the number of kisses by the number of hugs.
It’s definitely not perfect, but it’s fairly symmetrical. I sent it out as a geeky-cool Valentine to family and friends.
As I was adjusting the coordinates of the heart (for example, 6.5 hugs and 16.25 kisses), I had to ask myself: Is there such thing as half a hug or a quarter of a kiss? I decided the answer is yes because you could hug someone with just one arm and the Hollywood air kiss is barely a smooch.
Of course, this is not what JMP is for. But I must say it is fun to play with the software, even for a newbie like me. I’ve just started learning JMP, and it was easy to explore after I took the one-hour live (and free) Webcast, Getting a JMP Start.
You can download my data table with scatterplot script and two bubble plot scripts – which “draw” the heart in two ways by adding time into the mix – and see if you can improve upon my heart. Or why not contribute your own fun uses of JMP to our File Exchange?
Happy Valentine’s Day!
Article Labels
Article Tags
1 Comment
