Fall in Love with JMP
Searching for a way to understand your business data better? JMP may be the perfect match – no flowers required!
Check out our new interactive data story about a fictional candy maker. It shows you – step by step – how JMP joins together data from different sources, helps you see sales trends and enables you to gain insights about specific product lines using the data visualization capabilities of the software.
It gives you a taste of what JMP looks like and what it can do. If the data story piques your interest, download the fully functional trial version of JMP and explore it yourself using your own data. And be prepared to fall in love with JMP!
Article Labels
Article Tags
