Share your ideas for the JMP Scripting Unsession at Discovery Summit by September 17th. We hope to see you there!
XanGregg
Connected Trails in Bubble Plot
The most common question we get regarding Stephen Few's white paper and webcast on visualizing change is about the scripts for showing the connected trails in bubble plots. Often the existing bubble trails are overlapping, so the progression is clear, but when the bubble trails are spaced out it can be helpful to connect the bubbles with a line.
Bubble Plot with Connected Trails
In addition to the journal file that contains the data and plots from the paper, you can also download from the JMP Extras area the graphics script by itself which can be added to any bubble plot (via Right-Click and Customize) if you edit the column names in the script.
Local( {s = "", c = 0, xx = {}, yy = {}},
For Each Row(
If( Selected( Row State() ),
s = :State;
c = Color Of( Row State() );
Insert Into( xx, :Property Rate );
Insert Into( yy, :Violent Rate );
If( N Items( xx ) != 0 & (Row() == N Rows()
| !Selected( Row State( Row() + 1 ) )
| s != :State[Row() + 1]),
Pen Color( c );
Pen Size( 2 );
Transparency( 0.3 );
Line( Matrix( xx ), Matrix( yy ) );
xx = {};
yy = {};
The script requires that the data be sorted by the ID column, "State" in this case.
Article Labels
Article Tags
