XanGregg
Colors in JSL
In addition to more color options in the user interface, JMP 7 also adds more robust color control in JSL. JMP's encoding of palette colors as positive numbers has been expanded to encode 24-bit colors as negative numbers. Numbers representing colors in this way are called JSL color values. All places that take a color in JSL , such as Pen Color(), will also take a JSL color value.
The scripting language adds the following operators to manipulate JSL color values:
RGB Color
Create a color from red, green and blue components
HLS Color
Create a color from hue, saturation and lightness components
Heat Color
Create a color using one of JMP's color themes
Color to RGB
Extract red, green and blue components from a color value
Color to HLS
Extract hue, saturation and lightness components from a color value
Article Labels
Article Tags
