The Discovery Summit 2025 Call for Content is open! Submit an abstract today to present at our premier analytics conference.
Blogs
Read about a broad range of data analysis topics and posts that inform your JMP use.
Latest Posts
  • Importing and merging multiple XML files
    I needed to import and stack 660 XML files from my exercise activity tracking app. It's easy with the XML Import Wizard and Import Multiple Files in JMP 15.  
    Phil_Kay Phil_Kay
    JMPer Cable |
    Feb 26, 2025 3:53 AM
    6308 views | 4 replies
  • Propeller Perfection: Optimization Using JMP for Efficient Experimentation
    Efficient propeller design is crucial for the electric Vertical Takeoff and Landing (eVTOL) industry, which is projected to reach a market value of $15.8 billion by 2030, according to a report by Market Research Future. Propellers play a key role in optimizing performance, reducing energy consumption, and enhancing flight stability in eVTOL aircraft, which are designed to revolutionize urban air m...
    brycerjs8 brycerjs8
    JMPer Cable |
    Feb 24, 2025 9:07 AM
    301 views | 4 replies
    No supplied image
  • The art of what’s possible in semiconductor: Narrowing the variable list in design of experiments (DOE)
    Is it possible to optimize a plasma-enhanced chemical vapor deposition (PECVD) with just 25 test wafers? Absolutely! In semiconductor manufacturing, constraints such as a 25-wafer run on a tool are common, but they don’t have to limit success. Leveraging process data to inform experiment design is a winning strategy for getting effective results with limited resources.
    Jason_Wiggins Jason_Wiggins
    JMP Blog |
    Feb 21, 2025 12:00 PM
    172 views | 0 replies
  • The art of what’s possible in semiconductor: Making the best choice for defect count models
    In semiconductor manufacturing, defects can result in scrap and sunk costs. When not detected, they can adversely impact device functionality and cause end-user failures. Defects can lead to large financial losses and damaged reputations. There is value in making the statistical models used to minimize defects as accurate as possible. Standard least squares regression is often the go-to method for...
    JMP Blog |
    Feb 21, 2025 6:00 AM
    159 views | 0 replies
  • 「MaxDiff計画」を用いたキャラメルポップコーンのおいしさ調査
    「ポップコーンにキャラメルがかかっているだけで、こんなにおいしいなんて!」 筆者が初めてキャラメルポップコーンを食べたときの感動は今でも忘れられません。普段はあまりポップコーンを食べることはありませんが、キャラメルポップコーンだけは好んで食べています。 スーパーにいくと、さまざまなキャラメルポップコーンが販売されています。いくつか試してみると、「これはおいしい!」と思うものや、キャラメル感が強いもの、味が控えめなものなど、それぞれに特徴があることがわかりました。   ちょうどその頃、JMPに「MaxDiff計画」という新機能が追加されました。「これはキャラメルポップコーンのおいしさを調べるために使えそうだ!」と思い、弊社(JMP Japan)の社員に協力をお願いし、調査を実施しました。かなり前の調査にはなりますが、その結果を報告します。   MaxDiff計画とは? 消費者調査では、「選...
    Masukawa_Nao Masukawa_Nao
    Naohiro Masukawa |
    Feb 19, 2025 8:10 PM
    76 views | 0 replies
  • JMP® Marketplace Feature: S3 Data Connector
    The JMP S3 Data Connector in the JMP® Marketplace uses JMP's powerful Python integration to provide seamless access to Amazon Web Services (AWS) S3. You can configure your AWS credentials within the data connector editor and quickly import files that are compatible with JMP and are hosted on Amazon S3 remote connections. This integration streamlines data retrieval processes, enhancing your workflo...
    LandraRobertson LandraRobertson
    JMP Blog |
    Feb 19, 2025 9:00 AM
    146 views | 0 replies
    No supplied image
  • Accessing SAS using JMP 18, Python, and SASPy
    Using the scripting environment and a python package called SASPy, JMP 18 can interface with SAS instances, import data sets, export data sets, and run SAS code.
    chrishesser chrishesser
    JMP Blog |
    Feb 19, 2025 6:00 AM
    274 views | 0 replies
    No supplied image
  • 如何高效提升原物料建模效率、降低實驗成本?定量構效關係 (QSAR) 性能優化 4 步驟
    在化工或材料企業工作的你,如何有效提升新材料研發效率、降低實驗成本?透過QSAR方法,化工工程師可將多水準類別因子轉換為連續因子,並利用主成分分析減少變因數量,降低實驗次數與成本。結合JMP的Custom Design與PLS建模,可快速建立高效預測模型,優化材料選擇與製程設計。了解如何運用數據分析提升研發效率,探索更多實驗設計與建模技巧!
    JMP_Taiwan JMP_Taiwan
    JMP Blog |
    Feb 18, 2025 5:00 PM
    184 views | 0 replies
  • Control de Procesos y Automatización del SPC con JMP Live: Una Guía Práctica
    Descubre cómo JMP y JMP Live pueden transformar la gestión de datos en tu empresa mediante la automatización del SPC y las alertas automáticas en gráficos de control.
    MarilynWheatley MarilynWheatley
    JMP Blog |
    Feb 18, 2025 5:58 AM
    194 views | 0 replies
    No supplied image
  • From Picture to Data: Extracting graph data from a picture into a JMP Table for analysis
    Have you ever needed to import the data contained in an image of a graph into JMP? It turns out JMP can do this rather easily. Read on to find out how.
    Jed_Campbell Jed_Campbell
    JMP Blog |
    Feb 14, 2025 2:28 AM
    1511 views | 2 replies
  • Eficiencia sin código: Automatiza con el Constructor de flujo de trabajo de JMP
    El constructor de flujo de trabajo de JMP permite grabar los pasos que se toman haciendo clic en la interfaz de JMP, para que el trabajo sea repetible, para que los pasos se puedan aplicar cuando hay datos nuevos, o el flujo de trabajo entero se puede compartir con otras personas.
    JMP Blog |
    Feb 11, 2025 1:22 PM
    281 views | 0 replies
    No supplied image
  • Optimizing Multiple Curves in the Functional Data Explorer
    Can JMP be used to model, compare, and optimize multiple curves at the same time? I've been asked this a few times in the last month, and (of course) the answer is "yes." Read on to find out how.  
    JMP Blog |
    Feb 7, 2025 2:07 PM
    1092 views | 3 replies
  • Demystifying Factor Constraints
    Specifying constraints in a DOE can seem daunting, but it can be much easier than you imagine if you use some of the other tools in JMP to do the heavy lifting.
    JMP Blog |
    Feb 6, 2025 2:01 PM
    3416 views | 8 replies
  • Active Learning in JMP - Chris Gotwalt ENBIS Workshop
    Watch the recording of this workshop with Chris Gotwalt and Phil Kay.
    Phil_Kay Phil_Kay
    Phil Kay's Blog |
    Feb 4, 2025 5:24 AM
    816 views | 0 replies
  • Design evaluation of optimal designs
    Optimal designs use one of several optimality criteria based on the goal of the experiment. Using the design evaluation tools we can compare, and contrast designs based on the goal of the experiment. In each of the case studies below, the tools relevant for each experimental goal are explored.   Summary of practical goals and design evaluation tools I-optimal D-optimal Practical goal: Accurate ...
    O_Lippincott O_Lippincott
    JMPer Cable |
    Feb 3, 2025 2:01 PM
    387 views | 2 replies
    No supplied image
  • Writing JSL code dynamically
    Why doesn't my code work when I try to use a variable as an argument to ...?
    Jasean Jasean
    JMPer Cable |
    Jan 27, 2025 10:39 AM
    334 views | 1 replies
  • What are “optimal designs” and “optimality criteria”?
    JMP’s Custom Design platform allows experimenters to create custom-built designs for their specific experiment needs by constructing optimal designs. The custom designer generates optimal designs by seeking to maximize one of several optimality criteria using the coordinate-exchange algorithm. The coordinate-exchange algorithm constructs a starting design by selecting random values within the desi...
    JMPer Cable |
    Jan 23, 2025 11:30 AM
    515 views | 0 replies
    No supplied image
  • New features in JMP Clinical 18.1.2 and JMP Clinical 18.2
    JMP Clinical 18.1.2 (released on January. 21) and JMP Clinical 18.2 (which will be released in March) comes with several important features, including data quality reports, a configuration checking tool, autosaving and restoring the review builder templates.
    Valerie_Nedbal Valerie_Nedbal
    JMP Blog |
    Jan 22, 2025 9:53 AM
    677 views | 0 replies
  • 製造業品質提升指南:圖解FMEA失效模式分析與工具應用
    本篇文章深入探討如何運用JMP工具進行FMEA(失效模式與影響分析),有效管理製造業品質問題。了解多重回應、儲存格著色及Dashboard等功能如何助力品質分析與改進,讓失效分析更高效、更直觀。
    JMP Blog |
    Jan 22, 2025 5:43 AM
    526 views | 0 replies
  • 共変量を変化させたときの薬物動態モデルの考察
    下図は、12人の患者に特定の薬剤を投与した際の薬物濃度の時間経過を示す折れ線グラフです。薬物は投与後に体内で吸収され、濃度が急激に上昇した後、分布や代謝によって濃度が緩やかに低下します。このグラフは、薬物動態の基本的なパターンを示しています。 患者ごとの折れ線を観察すると、濃度の変化に個人差が見られます。この差異は通常、薬物の種類、投与経路、患者個々の特性(例:体重や代謝能力)などによるものです。   例えば、体重が大きい患者では分布容積が増加し、最大濃度(Cmax)が低くなる可能性があります。また、投与量や薬剤の種類によっても濃度推移が変化することがあります。   これら、薬物動態に影響を及ぼす可能性がある要素は「共変量」と呼ばれ、共変量の違いによって薬物濃度はどのように影響を及ぼすかを解析することがあります。   本ブログでは、JMP(JMP Pro) の「曲線のあてはめ」プラットフ...
    Naohiro Masukawa |
    Jan 21, 2025 4:00 PM
    225 views | 0 replies
