Jeff_Perkinson
Attention procrastinators: The time has come
Ask most anyone I work with, and they'll tell you that I need a deadline to make something happen.
If you're the same way, then the time has come for you.
The call for papers for Discovery Summit 2015 in San Diego closes Monday morning, March 9. That gives you less than 96 hours to write a couple of paragraphs explaining how you will:
  • demonstrate how you've used JMP to make important discoveries, or
  • share your favorite JMP tips and tricks, or
  • explain how you've applied JMP to advance analytic excellence at your organization.
  • As a procrastinator, you'll be pleased to find that right now all you need to create is an abstract describing your presentation. You'll have until September to actually create the presentation, so you've got plenty of time to enjoy putting that work off.
    Submit your abstract now, and let the next round of procrastination begin immediately.
    What? Are you still here reading this? You really are a procrastinator.
    Not that I should encourage that kind of behavior, but, if you need some inspiration, check out the papers from Discovery Summit 2014 to see what the conference steering committee is looking for.
    Now, go submit your abstract!
    Article Labels
    Article Tags
