This add-in can be used to embed a singular, or multiple Source tables as Table Scripts into a single Destination table. Doing so can help consolidate all of your data tables in one, easily accessible data table. Each Destination table contains an "Embed Source" table script, which provides the exact JSL script used to embed the Source table(s) into the Destination table, which can be used for scripting purposes.
Potential use cases:
- Embed a data table into its summarized table so the individual records are still available for viewing.
- JMP Live:
- JMP Live requires the use of summary tables in order for quick loading speeds. Being able to embed individual records into a summary table allows a JMP Live report to still run quickly while also preserving individual records for future examination.
