SAS Map Importer
jeffmoore
This add-in requires a connection to a SAS server.  It will list the SAS maps on the server and allow you to import them into JMP.
Select the SAS maps to convert on the left, then click the Convert Maps to JMP button.
When finished, the map will appear in the list of JMP maps on the right.
