This add-in will randomly make a melody based on some options you set, then your Mac will beatbox it to you. (Only works on Mac.)
The options are filled in with default values so Steps 1-5 are optional.
- Set the musical scale.
- Set the key.
- Set the octave range (the lower the octave, the deeper the voice).
- Fill in the phonics. You can use the default value, or use the instructions to change it.
- Set the number of bars and loops.
- Click the Generate Melody button.
