JMP Add-Ins
JMP User Community Add-In
Description
If you've ever wanted to check out the JMP Community without leaving the comfort of your JMP application, this is the add-in for you! The JMP User Community add-in allows you to view the latest 20 posts in the discussion forums, the File Exchange (Add-Ins, Scripts, Sample Data), JMP Blogs (JMP Blog, JMPer Cable, Uncharted), and now the JSL Cookbook!
Features
View Comments in Discussion Forum
In Display Box Mode, View and Run JSL from the JMP Script Editor
See something you like? Click the link to open the post in your browser
Settings
You can manage which forums and blogs appear in your window by changing your selections in the top-right corner. These settings are maintained across JMP sessions, so there is no need to adjust each time.
Removing unneeded forums and blogs decreases the amount of time it takes for the add-in to load. Changing the Display Type between "Browser Box" and "Display Boxes" changes the way posts are shown. However, only the "Display Boxes" option is available on Mac.
System Requirements
This add-in works in JMP 13 on Windows and Mac operating systems.
Updates
Version 1.1 (January 12, 2017)
Changelog:
  • Added support for viewing the JSL Cookbook.
  • Added ability to increase the number of posts retrieved (up to 100).
  • Changed name from "JMP User Community RSS Viewer" to simply "JMP User Community."
Comments
jules
Amazing, @Justin_Chilton!
