JMP 15.1 English Documentation PDF Files
Beginning with JMP 15, the Discovering JMP book, New Features, Quick Reference Card, Menu Card, and JMP Documentation Library PDF files are installed and linked in the Help menu. PDF files in the Help > Books menu are no longer installed.
JMP Documentation Library.pdf contains all books. However, some users might prefer the individual PDF files. Consider installing the JMP 15 English Documentation PDF Files in English add-in to create a Help > Books menu item with linked PDF files (such as Using JMP and Fitting Linear Models).
Comments
It's great to have that in JMP 15.  Thank you very much.
I'm glad you found the add-in helpful.
Thank you Sheila.  Consolidating all the books into 1 document is probably my least favorite new feature.  I'm so glad to have the Books menu back!
@cwillden, thank you for your feedback! Several years ago, we split the JMP books into smaller books. For example, the Basic Analysis and Graphing book was split into two books -- Basic Analysis and Essential Graphing. To prevent the need for users to know which book to search in, we began providing the JMP Documentation Library PDF file.
Some users like it. Others, like you, prefer the individual PDF files.
I will pass along your feedback to the development and product marketing team.
Sheila Loring
Manager, Technical Writing
Article Labels
Article Tags
