Helps convert places names to longitude/latitude coordinates.
This add-in will go through a specified data table and check user-specified columns for location names or addresses. It will then check these places against internal data tables installed with the add-in or the online services of OpenStreetMaps.org. For example: say that you have a data table with American cities paired with some numerical data, and you want to view this information on a map with JMP. You can use this add-in to find latitude and longitude coordinates for each of the different cities, and then creating your map is rather easy.
Author: intern David Spruill
Updated April 4, 2016 with extra error check and reduced data base size.
Related blog post: A JMP add-in to geocode your geographic data - JMP Blog
