Have your say in shaping JMP's future by participating in the new JMP Wish List Prioritization Survey
Functional Data Explorer - Actual vs Predicted Diagnostics Add-In
Requirements:
-data table with functional data.
-a functional data explorer (FDE) script saved to the data table.
As presented in the JMP Europe Discovery Summit 2021
Functional Data Explorer: Turning Knowledge Into Value (2021-EU-30MP-777)
Explore an example on JMP Public: https://public.jmp.com/packages/2llssr3Kf9DgWsX050vrt
The Function Data Explorer - Actual vs Predicted Diagnostics Add-In will:
  • Look for FDE scripts in the current data table.
  • Run a selected script.
  • Extract Y, X, ID, Z variables from the script.
  • Identify what FDEs have been performed and whether they have had their FDOE triggered.
  • Triggers save prediction, residual summaries (if v15.1 or above and FDOEs present) and function summaries.
  • Loops through Function Summaries separate data tables, adds them to copy of main data table and renames columns.
  • Identifies what Prediction and Residual Formulas have been added to data table copy.
  • Makes Actual vs Predicted graph, if prediction columns exist, saves to data table copy.
  • Makes an R2 graph, if prediction columns exist, saves to data table copy.
  • Makes Residual Graph, if residual columns exist, saves to data table copy.
  • Changes copied data table name to "[FDE - AvsP] " || <original data table name>.
Comments
Raaed
not run
benfrancis
Hi raewdy, that's a shame. Could you provide some specifics? Was the add in used on an open data table with an FDE script saved?
Raaed
benfrancis
Hi @Raaed, I see the issue. This Add-In requires a JMP data table of functional data (for example, a response over time) with a Functional Data Explorer script saved to it. I've updated the description above to reflect this.
To see an example, navigate to https://public.jmp.com/packages/2llssr3Kf9DgWsX050vrt.
Raaed
thank you very much
