This is a revision of a tool for working with column names written by @XanGregg
From the original post (link:(
- Move Up the first row of data to be the column names.
- Move Up and Append the first row of data to be appended to the column names.
- Move Down the column names into the first row of data.
- Recode Names to change all the column names in one dialog. Note that for JMP 14, you need to use the JMP14 version of the add-in and select the "In Place" option in the Recode platform.
Notes:
2018-08-30: Added a second version of the Addin that accounts for some changes to the Recode Platform in JMP 14.
