This little add-in takes care of setting up a data table for an analysis involving the Auto-validation technique put forward by @chris_gotwalt1 and @philramsey at the 2018 JMP Discovery Summit Series (link to the paper and materials)
After installation, the add-in is run by selecting Add-ins > Autovalidation Set-up in JMP. The Add-in looks for an open data table and then creates a copy with the required formatting to run the workflow.
