Textbook Add-In: Statistics with JMP - Graphs, Descriptive Statistics and Probability
Statistics with JMP:  Graphs, Descriptive Statistics, and Probability
Peter Goos and David Meintrup
John Wiley & Sons Ltd. 2015
This add-in provides a journal containing all of the data sets provided in the textbook, along with links to useful resources for learning and using JMP and the Wiley Companion Site for the textbook.
Additional information and resources for the textbook can be found at the Wiley textbook page.
Add-in notes:  To install the add-in, open the file in JMP and tell JMP to install it.  In the Add-ins menu (which will be new if you don't have any other add-ins installed), there will be menu item that will open the journal. The add-in installs the journal, along with supporting data sets and scripts, locally on your machine. Everything is accessible via the journal. There are many teaching and learning tools under the JMP Scripts and Tools outline.
When you close the journal, or any associated data set, we recommend that you do not save changes unless you've intentionally changed something (like a data type).
Developed by the authors for classroom use. With each purchase of a hard copy of this book, you receive a two-year license for JMP Student Edition.
A companion book "Statistics with JMP: Hypothesis Tests, ANOVA and Regression" by the same authors and following the same philosophy will be published in April 2016.
Suggestions or feedback, or find any problems with the add-in? Let us know at  mia.stephens.
Article Tags
Contributors
