Submit your abstract to the call for content for Discovery Summit Americas by April 23. Selected abstracts will be presented at Discovery Summit, Oct. 21- 24.
Discovery is online this week, April 16 and 18. Join us for these exciting interactive sessions.
JMP Add-Ins
Featured Items
  • Add-In Guidelines
    Add-in guidelines are intended to ensure consistency and integrity with the add-ins available in the File Exchange.    Use best practices for scoping and namespaces. Review the “Advan...
    Ryan_Gilmore
    JMP Add-Ins |
    Mar 21, 2023 7:17 AM
    2832 views | 0 replies
  • OMARS Explorer
    Here is an add-in to allow people to generate and select OMARS experimental designs for 5, 6 or 7 factor experiments. The add-in was presented at the 2022 JMP Discovery Summit Europe, OMARS Designs A...
    HadleyMyers
    JMP Add-Ins |
    Mar 31, 2022 6:02 AM
    1223 views | 0 replies
  • XGBoost Add-In for JMP Pro
    New for JMP 17 Pro:  An Autotune option makes it even easier to automatically tune hyperparameters using a Fast Flexible Filling design.     The XGBoost add-in for JMP Pro pro...
    russ_wolfinger
    JMP Add-Ins |
    Feb 5, 2024 4:38 AM
    18600 views | 66 replies
  • Word Import Tool
      Description  The Word Import Tool add-in allows you to import text, tables, or images from a Word document. It can also create a table summarizing one or more Word documents. Laun...
    Justin_Chilton
    JMP Add-Ins |
    Jun 23, 2023 10:47 AM
    15693 views | 9 replies
  • Data Table Tools Add-in
    This addin contains several utilities for working more efficiently with data tables. With it, you can:   Quickly set the number of decimal places displayed in the data table. Set and cha...
    brady_brady
    JMP Add-Ins |
    Feb 15, 2024 12:52 PM
    26228 views | 32 replies
  • Semiconductor Toolkit
    (18Aug2019) - A note from the author Hi, All!  It's time to start thinking about a new version of the STK... I've got some things that I'd like to do, but I also want to hear from those using ...
    MikeD_Anderson
    JMP Add-Ins |
    Feb 26, 2024 8:28 AM
    93615 views | 102 replies
  • Contact JMP Technical Support Add-in
    How can JMP Technical Support help you?   To make reaching out to Technical Support easier for you, we have created the Contact JMP Technical Support Add-In.  This Add-In will open...
    Justin_Chilton
    JMP Add-Ins |
    Oct 22, 2021 6:54 AM
    13634 views | 6 replies
  • Journal Text Sledgehammer
    The Journal Text Sledgehammer is a tool for bulk formatting of TextEditBoxes within journals.   To use:   Open the Journal(s) you want to edit. If no journals are open, the p...
    brady_brady
    JMP Add-Ins |
    Dec 26, 2023 5:01 AM
    12726 views | 16 replies
Latest Posts
  • JMP Acceptance Sampling Plan Add-In
    The acceptance sampling plan add-in provides a point-and-click interface for generating / creating, evaluating and comparing sampling plans. Specifically, one can create sampling plans by lot accep...
    stan_koprowski
    JMP Add-Ins |
    Apr 19, 2024 7:50 AM
    8806 views | 33 replies
  • Capability Explorer
    Purpose   The Capability Explorer add-in provides an interactive, six-graph summary for evaluating process capability. The report provides a process capability analysis and allows users to e...
    scott_allen
    JMP Add-Ins |
    Apr 18, 2024 2:04 PM
    2118 views | 5 replies
  • Capability Analysis JMP Add-In
    Purpose This add-in is designed to produce an attractive graphical rendition of a process capability study, and to make it easy to perform analyses across multiple columns of data.   How t...
    David_Burnham
    JMP Add-Ins |
    Apr 18, 2024 2:08 AM
    15070 views | 17 replies
  • Spectris: Graphical spectral data processing
    Purpose This add-in provides a needed bridge between the capabilities of the Nonlinear/Fit Curve platforms and Functional Data Explorer.  It is designed to handle common spectroscopic tasks li...
    MikeD_Anderson
    JMP Add-Ins |
    Apr 17, 2024 9:10 AM
    1932 views | 8 replies
  • Unit Conversion Add-In
    This Add-In allows you to define and check the physical units of your columns and then convert them to different units. For example, define a column in milliliters/hectare and then convert it, a...
    EvanMcCorkle
    JMP Add-Ins |
    Apr 15, 2024 10:59 AM
    75 views | 0 replies
  • Tools for Battery Analysis
    This add-in contains tools for the analysis of data from Electrochemical Impedance Spectroscopy (EIS). It wraps functionality from the Python Package Impedance.py.   After installing the add...
    Jordan_Hiller
    JMP Add-Ins |
    Mar 27, 2024 1:02 PM
    163 views | 0 replies
  • Torch Deep Learning Add-In for JMP Pro
      Purpose   The Torch Deep Learning Add-In for JMP® Pro provides a no-code interface to the popular Torch  library for predictive modeling with deep neural networks.  T...
    SamGardner
    JMP Add-Ins |
    Mar 25, 2024 5:43 PM
    1520 views | 1 replies
  • German Documentation Add-In
    The Documentation add-in installs the individual PDF files for all JMP books, and the Documentation Library, which is a concatenation of all the books into one PDF. The add-in also installs a new men...
    Qiana_Eaglin
    JMP Add-Ins |
    Mar 14, 2024 3:01 PM
    124 views | 0 replies
  • Spanish Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    Mar 14, 2024 3:00 PM
    122 views | 0 replies
  • French Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    129 views | 0 replies
  • Italian Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    111 views | 0 replies
  • JMP Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    Mar 13, 2024 1:17 PM
    527 views | 0 replies
  • Korean Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    Mar 13, 2024 1:16 PM
    229 views | 0 replies
  • Chinese Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    323 views | 0 replies
  • Japanese Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    Mar 13, 2024 1:15 PM
    282 views | 0 replies
  • English Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    Mar 13, 2024 1:14 PM
    457 views | 0 replies
  • Machine Learning with XGBoost
    Purpose Here is an attempt of my first application built with app-builder using the connection between JMP and Python to handle a complex machine learning algorithm. The purpose of this app is to...
    Franck_R
    JMP Add-Ins |
    Mar 13, 2024 12:03 AM
    5833 views | 14 replies
  • Rank Based Inverse Normal Transformation (INT) for Quantitative Trait Data
    This JMP Add-in is to transform non-normal quantitative trait data typically analyzed in Genome Wide Association Studies (GWAS). The method implemented is rank-based inverse normal transformatio...
    Chris_Kirchberg
    JMP Add-Ins |
    Mar 12, 2024 9:39 AM
    708 views | 3 replies
  • Apache Parquet file importer
    This add-in imports interactively Apache Parquet files (https://parquet.apache.org/) into JMP tables. It consists of two commands: Single file: select a single .parquet file, checks its validit...
    MassimoMartucci
    JMP Add-Ins |
    Mar 7, 2024 2:08 PM
    1680 views | 8 replies
  • Column Quick Swapper - easily change multiple Y and X-axis columns in Graph Builder
    Note: This was previously called Column Filter (jthi.column.filter). Uninstall that version before installing this.   This add-in lets you easily change multiple columns in your Graph Builde...
    JMP Add-Ins |
    Mar 6, 2024 3:57 PM
    420 views | 1 replies
  • Neural Network Tuning
    Updates November 27, 2023 - Version 1.1 - improvements and bug fixes, details are in a post below November 28, 2023 - Version 1.11 - minor bug fix December 15, 2023 - Version 1.2 - im...
    scott_allen
    JMP Add-Ins |
    Mar 5, 2024 9:09 AM
    3271 views | 18 replies
  • Table Attributes Add-In
    Description   Have you ever needed to share data and collaborate with a colleague who is not a JMP user?  Perhaps you export data to Excel for those colleagues, only to lose the JMP for...
    Justin_Chilton
    JMP Add-Ins |
    Feb 28, 2024 12:52 PM
    23489 views | 25 replies
    MikeD_Anderson
    JMP Add-Ins |
  • Imbalanced Classification Add-In
    The Imbalanced Classification add-in features sampling techniques that attempt to impose a more balanced distribution between the two classes. The sampling techniques include the synthetic minority o...
    michael_jmp
    JMP Add-Ins |
    Feb 23, 2024 8:11 AM
    6058 views | 25 replies
  • Top N Pareto Front Search for Structured Decision-Making
    This is an Add-In to facilitate a decision-making process where multiple criteria are considered. The method uses layered Pareto Fronts to reduce the number of choices from which to choose and also a...
    seburke89
    JMP Add-Ins |
    Feb 22, 2024 10:58 AM
    4808 views | 3 replies
