julian
Simulating the estimation of the population variance (Why n-1?)
Video Demo
The attached script is useful for demonstrating the bias in estimating the population variance/standard deviation without using the corrected sample estimator (with n-1). This script can be used during lecture to demonstrate the concept, or can be given to students to use an an exploratory exercise.
Usage:
1. Run the attached script by pressing Control-R (on the PC), and Command-R (on the Mac).
2. Specify the population parameters, sample size, and number of sample to draw. (10k or more samples is recommended, and should take less than ~3 seconds on most computers)
3. The table of sample estimates will be generated, including:
  • Sample Number
  • Sample Size
  • Sums of Squares for each sample
  • Variance, estimated using the population form (with N in the denominator)
  • Variance, estimated using the sample estimator form (with n-1 in the denominator)
  • Standard Deviation, estimated using the population form (with N in the denominator)
  • Standard Deviation, estimated using the sample estimator form (with n-1 in the denominator)
4. Run the saved scripts in the table to visualize and interact with the observed estimates. In the interface you can:
  • Show the population variance/standard deviation on the histogram
  • Show the observed mean estimate of the selected statistic
For ideas on using this script, see the Video Demo that I use in my course.
This script was developed in collaboration with mia.stephens. Please post any suggestions for future versions.
We hope this helps with your teaching!
julian
Article Tags
Contributors
