JMP Add-Ins
Latest Posts
  • German Documentation Add-In
    The Documentation add-in installs the individual PDF files for all JMP books, and the Documentation Library, which is a concatenation of all the books into one PDF. The add-in also installs a new men...
    Qiana_Eaglin
    JMP Add-Ins |
    Mar 14, 2024 3:01 PM
    33 views | 0 replies
  • Spanish Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    Mar 14, 2024 3:00 PM
    40 views | 0 replies
  • French Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    24 views | 0 replies
  • Italian Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    32 views | 0 replies
  • JMP Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    Mar 13, 2024 1:17 PM
    194 views | 0 replies
  • Korean Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    Mar 13, 2024 1:16 PM
    81 views | 0 replies
  • Chinese Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    95 views | 0 replies
  • Japanese Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    Mar 13, 2024 1:15 PM
    62 views | 0 replies
  • English Documentation Add-In
    Qiana_Eaglin
    JMP Add-Ins |
    Mar 13, 2024 1:14 PM
    110 views | 0 replies
  • Machine Learning with XGBoost
    Purpose Here is an attempt of my first application built with app-builder using the connection between JMP and Python to handle a complex machine learning algorithm. The purpose of this app is to...
    Franck_R
    JMP Add-Ins |
    Mar 13, 2024 12:03 AM
    5323 views | 14 replies
  • Rank Based Inverse Normal Transformation (INT) for Quantitative Trait Data
    This JMP Add-in is to transform non-normal quantitative trait data typically analyzed in Genome Wide Association Studies (GWAS). The method implemented is rank-based inverse normal transformatio...
    Chris_Kirchberg
    JMP Add-Ins |
    Mar 12, 2024 9:39 AM
    544 views | 3 replies
  • Apache Parquet file importer
    This add-in imports interactively Apache Parquet files (https://parquet.apache.org/) into JMP tables. It consists of two commands: Single file: select a single .parquet file, checks its validit...
    MassimoMartucci
    JMP Add-Ins |
    Mar 7, 2024 2:08 PM
    1345 views | 8 replies
  • Column Quick Swapper - easily change multiple Y and X-axis columns in Graph Builder
    Note: This was previously called Column Filter (jthi.column.filter). Uninstall that version before installing this.   This add-in lets you easily change multiple columns in your Graph Builde...
    JMP Add-Ins |
    Mar 6, 2024 3:57 PM
    217 views | 1 replies
  • Neural Network Tuning
    Updates November 27, 2023 - Version 1.1 - improvements and bug fixes, details are in a post below November 28, 2023 - Version 1.11 - minor bug fix December 15, 2023 - Version 1.2 - im...
    scott_allen
    JMP Add-Ins |
    Mar 5, 2024 9:09 AM
    2785 views | 18 replies
  • Table Attributes Add-In
    Description   Have you ever needed to share data and collaborate with a colleague who is not a JMP user?  Perhaps you export data to Excel for those colleagues, only to lose the JMP for...
    Justin_Chilton
    JMP Add-Ins |
    Feb 28, 2024 12:52 PM
    23114 views | 25 replies
  • Semiconductor Toolkit
    (18Aug2019) - A note from the author Hi, All!  It's time to start thinking about a new version of the STK... I've got some things that I'd like to do, but I also want to hear from those using ...
    MikeD_Anderson
    JMP Add-Ins |
    Feb 26, 2024 8:28 AM
    91347 views | 102 replies
  • Imbalanced Classification Add-In
    The Imbalanced Classification add-in features sampling techniques that attempt to impose a more balanced distribution between the two classes. The sampling techniques include the synthetic minority o...
    michael_jmp
    JMP Add-Ins |
    Feb 23, 2024 8:11 AM
    5693 views | 25 replies
  • Top N Pareto Front Search for Structured Decision-Making
    This is an Add-In to facilitate a decision-making process where multiple criteria are considered. The method uses layered Pareto Fronts to reduce the number of choices from which to choose and also a...
    seburke89
    JMP Add-Ins |
    Feb 22, 2024 10:58 AM
    4652 views | 3 replies
  • Calculate Effect Sizes Add-in
    This add-in ingests estimates from an ordinary least squares report (produced by Fit Model) and saves a table of model effect estimates, F-ratios, p-values, and three measures of effect size as formu...
    julian
    JMP Add-Ins |
    Feb 19, 2024 1:49 PM
    34384 views | 34 replies
  • Data Table Tools Add-in
    This addin contains several utilities for working more efficiently with data tables. With it, you can:   Quickly set the number of decimal places displayed in the data table. Set and cha...
    brady_brady
    JMP Add-Ins |
    Feb 15, 2024 12:52 PM
    25524 views | 32 replies
  • Bayesian optimization add-in
      このアドインについて このアドインは、JMPのガウス過程モデルを利用して、ベイズ最適化を行うためのアドインです。 システム要件 JMP 15以降 表示言語は、英語および日本語のみ   ベイズ最適化について ベイズ最適化は、逐次的な実験を繰り返し行い、最適解を探すときに使用される手法の一つです。ベイズ最適化の主な流れは、次の通りです。...
    yuichi_katsumur
    JMP Add-Ins |
    Feb 14, 2024 11:02 PM
    5334 views | 12 replies
  • Data Analysis Director
    This is designed to help new users become comfortable with running different analyses in JMP.  The add-in will ask the user to pick an analysis task, analysis goal, and data type.   ...
    Peter_Hersh
    JMP Add-Ins |
    Feb 9, 2024 2:57 PM
    6442 views | 15 replies
  • Conversion Function Library
      This add-in provides a library of common conversion functions for length, area, volume, mass, energy and temperature, time, speed and pressure, as well as some miscellaneous conversions, inc...
    ChrisCostin
    JMP Add-Ins |
    Feb 8, 2024 1:53 PM
    3920 views | 1 replies
  • Forest Plot Add-In
    The Forest Plot add-in displays several confidence or credible intervals vertically. The user supplies the lower and upper limits, the center value (which could represent the mean effect) and labels ...
    Richard_Zink
    JMP Add-Ins |
    Feb 7, 2024 8:15 PM
    28865 views | 12 replies
  • XGBoost Add-In for JMP Pro
    New for JMP 17 Pro:  An Autotune option makes it even easier to automatically tune hyperparameters using a Fast Flexible Filling design.     The XGBoost add-in for JMP Pro pro...
    russ_wolfinger
    JMP Add-Ins |
    Feb 5, 2024 4:38 AM
    17191 views | 66 replies
