BookmarkSubscribe
Repeated Measures using Mixed Models (OPG)
Topics: Analyze repeated measures data using mixed models. Data in tall (stacked) format.
Category: Multivariate Methods
JMP features: Analyze > Fit Model.
Open One-Page Guide (PDF)
Watch short video:
Comments
bordini
@volker_kraft I watched your video, read the guides, but I still have some questions. Please, could you help me?
1 - How does JMP know which is the repeated structure in the model when using the Standard Least  Squares?
2 - Is there a difference in the analyses when I use the Standard Least  Squares versus the Mixed model platform for a repeated measures design?
2 - I have a data which when using the Mixed Model my "subject" is Chemistry*Rep. However, I'm not able to cross them (Rep and Chemistry) and add it as a "subject".  What could I do in this situation?
Thank you so much!
Article Labels
Article Tags
Contributors
