Fewer boostrap samples than requested
Hello. I am trying to use the bootstrap function on a parameter table. I asked for 1,000 samples but the results are fewer than 1,000. After manually checking the data table, I noticed some BootIDs w...
tMinnxFind courses, tutorials, and lots of other methods of learning JMP.
view all learning resourcesHello. I am trying to use the bootstrap function on a parameter table. I asked for 1,000 samples but the results are fewer than 1,000. After manually checking the data table, I noticed some BootIDs w...
tMinnxWhat is the effect of declaring one of your variables as an "X, Factor" on the outcome of the MCA?
MusselManHi As I know it, there is no test to get the Mauchly sphericity test when doing RM-ANOVA in the Univariate approach. Is there any way to get this, instead of doing the analysis in t...
JonkandonkanHello, I am a beginner user of JMP since I have recently finished the DOE course provided by Coursera. However, I have to use it in my project and so, I am trying to use JMP community forums...
Nafis1991Hello, I am trying to fit a definitive screening design with a dataset that I already have. I would like to write a JSL script that would fit the design 1000 times. Would anyone be able to t...
ECGA94German Webinar at 10:00 CEST Mit JMP 17 wurde ein neuer interaktiver Profiler eingeführt, um...
French Webinar at 11:00 CEST. JMP 17 propose un profileur interactif qui permet d'explorer l'...
English Wevinar at 12:00 CEST (11:00 CET) JMP 17 introduced an interactive profiler to explor...
This webinar is in English, 2:00 p.m. US Eastern Time. JMP and JMP Pro offer techniques for i...
