BookmarkSubscribeRSS Feed
Highlighted
physicalchem20
Community Trekker
May 12, 2015
adding axial points in augment design
I want to augment a mixture design of three factors by adding axial point. but the augment window is not showing 'add axial' option there? how can i add axial points?
1 ACCEPTED SOLUTION
Accepted Solutions
mia_stephens
May 28, 2014
Solution
Re: adding axial points in augment design
Mixture designs are constrained - factors can only take on values between 0 and 1, and the factors (components in the mixture) must sum to 1 (100%).  The design space is a triangular rather than cubic (as you'd see in a factorial design). I believe that, because of these constraints, adding axial points from the augment platform for mixture designs is not available.
mia_stephens
May 28, 2014
Solution
MonaKhoddam
Community Member
Apr 30, 2017
But there are some mixture designs including axial runs. In this case, axial runs are located in the interior of the design space, on the line connecting each vertex to the overall centroid.
physicalchem20
Community Trekker
May 12, 2015
mia.stephens
anything else where i can get mixture of three factors and axial point to get triangle?
mia_stephens
May 28, 2014
There are different types of mixture designs that can be generated from the DOE > Mixture Design platform.  The Simplex Centroid and Simplex Lattice both place points on the edge of the design space. The Simplex Lattice also places design points in the interior of the design space.
In the ternary plots below, I generated the default designs, and then used the Graph > Ternary Plot option - you can see where the design points are placed relative to the triangle (i.e. the design space).  The optimal option allows you to create optimal custom mixture designs. - this gives you flexibility in the size of the experiment and the terms (parameters) you need to estimate.
There's a nice description of these designs and the mixture design platform in the JMP Book DOE Guide (under the Help Menu, Books - search for Mixture).
I hope this helps!
Mia
Default Simplex Centroid - 3 factors
Default Simplex Lattice
An optimal mixture design (using the default settings):
