Subscribe Bookmark RSS Feed
Re: Method to use in random effects model?
kkoprow
Community Trekker
Jun 15, 2016
I wish to create a random effects model for some data. To do so I select the "random effect" attribute for my model effect variable. I see from this page that I can choose between REML and EMS as my model fitting method. My questions are: When would I select one over the other and is there any difference between the two? I have attached a sample data set from Montgomery's text.
1 ACCEPTED SOLUTION
Accepted Solutions
DonMcCormack
Jun 23, 2011
Solution
REML estimates are independent of the fixed effects in the models. When data are balanced, or nearly balanced, this will make little difference and the estimates should be close. When data are unbalanced, EMS estimates may become adversely effected (even to the point of giving you negative variance components). You don't lose anything by sticking with the default REML. About the only time I would use EMS is when I wanted to match historical results in cases where EMS was used.
Don
DonMcCormack
Jun 23, 2011
Solution
Don
kkoprow
Community Trekker
Jun 15, 2016
Sorry for the late response. Thank you for your answer!
Highlighted
jdkurtis
Community Trekker
Dec 14, 2016
As a quick follow-on.... I am trying to fit a random effect in a model that has a binary outcome. JMP13Pro does not seem to be able to do this... Is there a work-around ?
thx
jake
PS- i've been asking JMP tech support to implement this since JMP6.. :((
