Add-In Guidelines
Add-in guidelines are intended to ensure consistency and integrity with the add-ins available in the File Exchange. Use best practices for scoping and namespaces. Review the “Advan...
Ryan_GilmoreAdd-in guidelines are intended to ensure consistency and integrity with the add-ins available in the File Exchange. Use best practices for scoping and namespaces. Review the “Advan...
Ryan_GilmoreHere is an add-in to allow people to generate and select OMARS experimental designs for 5, 6 or 7 factor experiments. The add-in was presented at the 2022 JMP Discovery Summit Europe, OMARS Designs A...
HadleyMyersNew for JMP 17 Pro: An Autotune option makes it even easier to automatically tune hyperparameters using a Fast Flexible Filling design. The XGBoost add-in for JMP Pro pro...
russ_wolfingerDescription The Word Import Tool add-in allows you to import text, tables, or images from a Word document. It can also create a table summarizing one or more Word documents. Laun...
Justin_ChiltonThis addin contains several utilities for working more efficiently with data tables. With it, you can: Quickly set the number of decimal places displayed in the data table. Set and cha...
brady_brady(18Aug2019) - A note from the author Hi, All! It's time to start thinking about a new version of the STK... I've got some things that I'd like to do, but I also want to hear from those using ...
MikeD_AndersonHow can JMP Technical Support help you? To make reaching out to Technical Support easier for you, we have created the Contact JMP Technical Support Add-In. This Add-In will open...
Justin_ChiltonThe Journal Text Sledgehammer is a tool for bulk formatting of TextEditBoxes within journals. To use: Open the Journal(s) you want to edit. If no journals are open, the p...
brady_bradyPurpose This add-in is designed to produce an attractive graphical rendition of a process capability study, and to make it easy to perform analyses across multiple columns of data. How t...
David_BurnhamPurpose The Capability Explorer add-in provides an interactive, six-graph summary for evaluating process capability. The report provides a process capability analysis and allows users to e...
scott_allenPurpose This add-in provides a needed bridge between the capabilities of the Nonlinear/Fit Curve platforms and Functional Data Explorer. It is designed to handle common spectroscopic tasks li...
MikeD_AndersonThis Add-In allows you to define and check the physical units of your columns and then convert them to different units. For example, define a column in milliliters/hectare and then convert it, a...
EvanMcCorkleThis add-in contains tools for the analysis of data from Electrochemical Impedance Spectroscopy (EIS). It wraps functionality from the Python Package Impedance.py. After installing the add...
Jordan_HillerPurpose The Torch Deep Learning Add-In for JMP® Pro provides a no-code interface to the popular Torch library for predictive modeling with deep neural networks. T...
SamGardnerThe Documentation add-in installs the individual PDF files for all JMP books, and the Documentation Library, which is a concatenation of all the books into one PDF. The add-in also installs a new men...
Qiana_EaglinThe Documentation add-in installs the individual PDF files for all JMP books, and the Documentation Library, which is a concatenation of all the books into one PDF. The add-in also installs a new men...
Qiana_EaglinPurpose Here is an attempt of my first application built with app-builder using the connection between JMP and Python to handle a complex machine learning algorithm. The purpose of this app is to...
Franck_RThis JMP Add-in is to transform non-normal quantitative trait data typically analyzed in Genome Wide Association Studies (GWAS). The method implemented is rank-based inverse normal transformatio...
Chris_KirchbergThis add-in imports interactively Apache Parquet files (https://parquet.apache.org/) into JMP tables. It consists of two commands: Single file: select a single .parquet file, checks its validit...
MassimoMartucciNote: This was previously called Column Filter (jthi.column.filter). Uninstall that version before installing this. This add-in lets you easily change multiple columns in your Graph Builde...
jthiUpdates November 27, 2023 - Version 1.1 - improvements and bug fixes, details are in a post below November 28, 2023 - Version 1.11 - minor bug fix December 15, 2023 - Version 1.2 - im...
scott_allenDescription Have you ever needed to share data and collaborate with a colleague who is not a JMP user? Perhaps you export data to Excel for those colleagues, only to lose the JMP for...
Justin_Chilton(18Aug2019) - A note from the author Hi, All! It's time to start thinking about a new version of the STK... I've got some things that I'd like to do, but I also want to hear from those using ...
MikeD_AndersonThe Imbalanced Classification add-in features sampling techniques that attempt to impose a more balanced distribution between the two classes. The sampling techniques include the synthetic minority o...
michael_jmpThis is an Add-In to facilitate a decision-making process where multiple criteria are considered. The method uses layered Pareto Fronts to reduce the number of choices from which to choose and also a...
seburke89This add-in ingests estimates from an ordinary least squares report (produced by Fit Model) and saves a table of model effect estimates, F-ratios, p-values, and three measures of effect size as formu...
julian
