Does JMP have a max character length for a file name?
Hi All, I'm working with a script that has worked just fine in the past, but doesn't seem to be working, and I think it's because the file name is too long. So, I have...
SDF1Find courses, tutorials, and lots of other methods of learning JMP.
view all learning resourcesHi All, I'm working with a script that has worked just fine in the past, but doesn't seem to be working, and I think it's because the file name is too long. So, I have...
SDF1Follow the script below. dt = Open( "$SAMPLE_DATA/Big Class.jmp" ); p1 = dt << Graph Builder( Variables( X( :weight ), Y( :height ), Group X( :age ), Color( :sex ) ), Elements( Bar( X, Y, L...
lalaHi, I am rather new to JMP so perhaps I am missing something obvious. I would like to run a paired t-test. I made a toy dataset with 8 cases and 2 columns: one "before" and one "after". Running a p...
RankBarracuda15I want to use jsl to split data in column "result" with delimiter "|" to new column "PIN" and "value". Kindly help, thank you in advance Please refer my attachment new table
ducthinh279Hello everyone, I've tried to create a sort of mixture design using a script. The script allows me to have 10 components (a1, a2 - b1, b2, b3, b4 - c1, c2 - d1, d2) and my mixture would consist of ...
PepinLB4 Day Course Monday, April 1 | 1:00 p.m. - 4:30 p.m. ET Tuesday, April 2 | 1:00 p.m. - 4:30 p.m. E...
Register here: https://www.jmp.com/en_us/events/live-webinars/academic/teaching-life-sci-03apr2024.h...
This webinar is in English, 2:00 p.m. US Eastern Time. See how to use design and analyze and...
4 Day Course Monday, April 15 | 1:00 p.m. - 4:30 p.m. ET Tuesday, April 16 | 1:00 p.m. - 4:30 p.m....
