Registration open for Discovery Summit Europe. User Group Members benefit from a 25% discount with the code: DSEUgroup24
alan_ruttle
Level II
Prime Numbers
Does anyone know if there is a way to search for prime numbers in JMP?
1 ACCEPTED SOLUTION
Accepted Solutions
ian_jmp
Re: Prime Numbers
Not that I know of, though I guess you could code something if you have the knowledge and know what you want.
Not sure it's worth it, though - See for example. You can download their software and 'win a cash prize' (?!) apparently . . .
5 REPLIES 5
ian_jmp
Re: Prime Numbers
alan_ruttle
Level II
Re: Prime Numbers
Thanks Ian,
I figured as much, I knew it was a long shot :) . I would be looking to find prime numbers within a fixed range and I know there are some algorithims out there I could use.
Re: Prime Numbers
Hi Alan,
Robert Anderson has found in the JMP 14 documentation a script for this:
https://www.jmp.com/support/help/14/create-an-interactive-program.shtml
The script only works for numbers up to 100, if you want to look for primes above that, you would have to modify the script.
Regards,
Maria
ian_jmp
Re: Prime Numbers
Unfortunately that script assumes you already know the answer (since it contains a list of primes).
alan_ruttle
Level II
Re: Prime Numbers
Thanks Maria, I would be looking at up to 90 digits.
