Text Explorer for Equipment Engineers
We can’t rely on error codes to correctly diagnose equipment problems.  Doing nothing is never an option, and whole units might be changed or replaced at great cost rather than identifying a specific component responsible.  Faults can also reoccur. An intermittent fault affecting a different unit or part of the equipment takes several failures before the true cause is diagnosed and identified.
Below is an example of how such an error can be quickly identified using the JMP Text Explorer.
Last Modified: Oct 23, 2020 7:30 AM
Comments
