Hello everyone,
The "Solving Problems through Data Visualization and Statistical Analysis" workshop was held on 9 June 2020 and repeated on 11 and 12 June 2020. In case you missed it, would like to see it again, or perhaps know a friend or colleague who might benefit, a recording of the event can be found below.
Note that the workshop was meant as a "hands-on" virtual event for you to be able to follow along. You can find the accompanying data set in the JMP Journal "JMP Discovered - Visualization and Statistical Analysis.jrn" below. If you don’t have one, you can download a free 30-day trial here.
Agenda:
1)The first step towards finding a permanent solution
Visualizing the problem
2)Could we have predicted this earlier?
How to stay ahead of out-of-control situations.
3)Identifying the key factors.
Visualizing the solution
4)Have we missed anything?
Using statistics to confirm we fully understand the situation.
5)What's the solution?
Finding the right settings to prevent the problem from reoccurring.
