New to using JMP? Hit the ground running with the Early User Edition of Discovery Summit. Register now, free of charge.
Getting Started with JMP: On Demand Course
Started ‎04-07-2023 by
Modified 2 weeks ago by
View Fullscreen Exit Fullscreen
Click the Begin! button below to start, or click Resume to return to where you left off. You can watch the videos in order, or jump to specific topics using the navigation pane on the left.
Download the Getting-Started-data.zip file linked above to follow along with the demonstrations. The Big Class.jmp data file is used in the introductory videos.
In these videos you'll learn about:
  • the four components of the JMP data table
  • manipulating and managing data by recoding data, adding column properties, and creating formulas
  • summarizing and joining data tables
  • importing data into JMP
  • using JMP analysis and graphing platforms such as Distribution and Graph Builder
  • saving scripts as part of a data table file, so you can easily recreate your analyses and share them with colleagues.
Comments
Amazing format: Short videos, great explanations, question to ensure that the content can be applied. Thank you very much for sharing. Could this format be useful for you?
 @Aziza @Steffen_Bugge @JohannD @shoffmeister @Ole_Luehn @Andreas_Büchse @Will_Penland @gerd @Peter_Vogel @Georg
Aziza
Excellent! Thanks for sharing!
MaanasaT
Love this format of Getting Started, especially the practice problems! Thank you for this!
jpol
Hi,
I am unable to download the Excel file "Product and Supplier Info.xlsx"  from the Resources menu.
When I attempt to do so I get the "Not Found" error message.
Is the link broken or is there some other issue?
Thanks,
Philip
jpol
jthi  provided another link where the Excel file is located:
Getting Started with JMP Journal and Data - JMP User Community
@jpol Thanks.
Wish I would have known about this sooner. @monique_lander were you aware of this resource?
Is there a cert at the end of the introductory module?
anis72
it is working now . thanks
@anis72 what is not working?  The files are downloadable on this page and also here: https://community.jmp.com/t5/Learning-Center/Getting-Started-with-JMP-Journal-and-Data/ta-p/512472
And the video is working  on Chrome and Edge.  If you send details I can try to help.
