BookmarkSubscribeRSS Feed
664786828
Community Trekker
why does not this word be executed
prefilepath=Set Default Directory( "C:\Users\Administrator\Desktop\新建文件夹\" );
filepath= Convert File Path( prefilepath, Windows );
filelists = Files In Directory(filepath);
lotfile="DFB-B2";
nf=N Items( filelists );
cctable= New Table( lotfile);//make an empty table
cctable<<New Column( "Source", Character, Nominal );
For( iii = 1, iii<= nf, iii++,
  filenow=(filelists[iii]);
         // If( Ends With( files, ".csv" ),
  dt= Open( filelists[iii] );
            dt<<new column("Source", Character, Nominal ) ;
           :Source<<set each value(filenow);
            dt<<new column("lotNO", Character, Nominal ) ;
            :lotNO<<Set each value(Insert( substr(filenow,1,2),:ChipID));
  dt<<run formulas();
            cctable << Concatenate( Data Table( dt ), Append to first table );
                  // Text Box( Regex( files, "(.+?)_", "\1" ) ) << journal; // All text before first "_" in file i's name is journaled
  close(dt,nosave);
cctable<<save("C:\Users\Administrator\Desktop\新建文件夹 (2)\","Concatenated data.jmp");
who can tell me why the last line is invalid??
Staff (Retired)
Re: why does not this word be executed
cctable is a column.  dt is a data table.  <<save is a message for a data table.  try
dt << save("C:\Users\Administrator\Desktop\新建文件夹 (2)\","Concatenated data.jmp");
edit: it looks like the data table, dt, is closed inside the loop.  More changes may be needed.
664786828
Community Trekker
cctable= New Table( lotfile);  //make an empty table
i don't think  cctable is a column;
so there may be something else wrong?
Staff (Retired)
I did not read your code carefully, sorry.  What messages are in the Log Window?  I think the <<save( filename ) should look like this:
<< save("C:\Users\Administrator\Desktop\新建文件夹 (2)\" || "Concatenated data.jmp");
or
<< save("C:\Users\Administrator\Desktop\新建文件夹 (2)\Concatenated data.jmp");
