BookmarkSubscribeRSS Feed
rainwang
Apr 21, 2016
what's the JSL code to save jmp report as a .pptx file
JMP12 has new function to save the jmp report as a .pptx file. while dose anyone know if I want to use jsl code to do this, how to write the code. can't find it in scripting guide.
thank you!
melaniedrake
May 30, 2014
Re: what's the JSL code to save jmp report as a .pptx file
db << Save Presentation is the command you want. It is in the Scripting Index, and also listed in the JSL Syntax Reference.
Full syntax (see the Syntax Reference for an explanation of the arguments):
db<<Save Presentation("path", <template("path")>, <(Insert("Begin"|"End"|N) | Replace("Begin"|"End"|N) | "Append")>, <Outline Titles("None"|"Hide"|"TopLeft"|"TopRight"|"BottomLeft"|"BottomRight")>, <format>)
rainwang
Apr 21, 2016
Thank you so much!
