billi
very basic line plot graph question
I am trying to re-create a graph that was plotted in excel (image of the plot is attached in file test excel). I tried plotting it in jmp but not getting the same graph. Data is attached and I have saved the graph that I got in the data table. Can anyone please help me with this simple graph?
Re: very basic line plot graph question
To start with, the time column in your JMP table is a character string and has the Ordinal modeling type. Convert it to numeric and continuous modeling type. That will give the proper scaling of your x-axis.
However, the graph will not look like the Excel chart because it is not the same data. For example, look at batch E. In the provided JMP table you show a percent of 43 at time 240. In the Excel graph you have a value in the 80s.
Dan Obermiller
Dan Obermiller
billi
@Dan_Obermiller Thank you for your reply. It worked and yes some of the values did not match but I got same graph if I use same values. Thank you again for your help.
Article Labels
