BookmarkSubscribeRSS Feed
FR60
Jan 24, 2017
variable reduction with clustering
Hi
I know that in the SAS/STAT package it is possible to find clusters of variables and then select the cluster representatives by using the 1-R2 ratio. Is there some thing similar in JMP?
Thanks.  Felice
ian_jmp
Jun 23, 2011
Solution
Re: variable redcution with clustering
Google is your friend here - 'Variable cluctering JMP' revealed this and this, amongst several others. I'm not familiar with the details of the method you cite, so you need to judge if what JMP can do is 'sufficiently similar'.
ian_jmp
Jun 23, 2011
Solution
FR60
Jan 24, 2017
Great.
Thanks.  Felice
