BookmarkSubscribeRSS Feed
ptnguyen
Oct 7, 2011
using variable in conditional formula to create new data column
data table(dtname)<<New Column( "PassFail",
    Character, Nominal,
    Formula( If( 0 < AColumnName< 100, "pass", "fail" ) ),
    Lock( 1 )
In the script message above; is there a way to replace the constant limits (0 and 100) with variables that have pre-assigned values?
pmroz
Jun 23, 2011
Re: using variable in conditional formula to create new data column
Yes.  You will need to preface the variable names with "::" so the column formula can see the values.  For example:
lower_limit = 0;
upper_limit = 100;
data table(dtname) << New Column( "PassFail",
    Character, Nominal,
    Formula( If( ::lower_limit < AColumnName < ::upper_limit, "pass", "fail" ) ),
    Lock( 1 )
