KinKame
Community Trekker
using table name as variable
hello
I would like to rename 3 tables and I tried to use a for loop as below, but without results so far.
Does anyone get any idea?
tb_list = {"SPC_tb", "SPEC_tb", "Data_tb"};
dtt = Data Table(tb_list[1]) << Get Selected;
For( k = 1, k < 4, k++,
  dtt = Data Table( eval(tb_list) << Get Selected[1] );
  name_list = dtt << get column names();
  column_name_tb = New Table( "xx_temp_name_table" );
  column_name_tb << New Column( "name", Character, Set Values( name_list ) );
  column_name_tb << New Column( "rename", formula( "rule" || :name ) );
  rename_list = Column( column_name_tb, "rename" ) << getValues;
  For( i = 1, i < N Col(dtt) + 1, i++,
  Eval( Column( dtt, i ) << set name( rename_list ) )
Lionel
Re: using table name as variable
I am not absolutely sure as to what you are attempting to do, however, if what I am detecting is the purpose of your code is to rename the columns in 3 data table, here is a piece of code that will do it:
For( k = 1, k <= 3, k++,
   dtt = Data Table( tb_list );
   For( i = 1, i < N Col( dtt ), i++,
      Column( dtt, i ) << set name( "rule" || Char( Column( dtt, i ) << get name ) )
KinKame
Community Trekker
works nicely. Good detection :-)
my mistake was to input in the list not the table name but the object associated.
SPC_tb = data table("SPC").
thank you!
