tova
using right y axis on graph builder and color coding
I am building a graph with graph builder.  I have 4 variables that I am showing on the y-axis, two on the left axis and two on the right axis.  I am using points, and would like the points to be color coded based on another variable (which happens to be color).  The color coding is working only for the variables using the left axis.  Is there a way I can color the right axis variables?
Thanks!
tova
Re: using right y axis on graph builder and color coding
I ended up solving my problem by using overlay, defining markers and colors, and then hiding whatever i wanted from the key.
Add Properties to Table( {New Script( "PmW Norm To Single Sub Frame AVG[Um] & 3 more vs. Nozzle ID 3", Graph Builder( Size( 1564, 941 ), Show Control Panel( 0 ), Variables( X( :Nozzle ID ), Y( :Name( "PmW Norm To Single Sub Frame AVG[Um]" ), Side( "Right" ) ), Y( :Name( "Line Width [Um]" ), Position( 1 ), Side( "Right" ) ), Y( :TIJ resistance, Position( 1 ) ), Y( :Pump resistance, Position( 1 ) ), Group X( :Pen, N View Levels( 1 ) ), Group X( :Die, N View Levels( 1 ), First View Level( 2 ) ), Group Y( :Bar, N View Levels( 1 ) ), Overlay( :Color ), Color( :Color ) ), Elements( Points( X, Y( 3 ), Y( 4 ), Legend( 20 ) ), Points( X, Y( 1 ), Y( 2 ), Legend( 21 ) ) ), SendToReport( Dispatch( {}, "400", ScaleBox, {Legend Model( 20, Properties( 0, {Line Color( 10 ), Marker( "Dot" )} ), Properties( 1, {Line Color( 0 ), Marker( "Dot" )} ), Properties( 2, {Line Color( 14 ), Marker( "Dot" )} ), Properties( 3, {Line Color( 9 ), Marker( "Dot" )} ), Properties( 4, {Line Color( 10 ), Marker( "Plus" )} ), Properties( 5, {Line Color( 10 ), Marker( "Dot" )} ), Properties( 7, {Marker( "Dot" )} ), Properties( 8, {Line Color( 14 ), Marker( "Plus" )} ), Properties( 9, {Line Color( 14 ), Marker( "Dot" )} ), Properties( 10, {Line Color( 9 ), Marker( "Plus" )} ), Properties( 11, {Line Color( 9 ), Marker( "Dot" )} ) ), Legend Model( 21, Properties( 4, {Line Color( 10 ), Marker( "X" )} ), Properties( 5, {Line Color( 10 ), Marker( "Y" )} ), Properties( 6, {Line Color( 0 ), Marker( "X" )} ), Properties( 7, {Line Color( 0 ), Marker( "Y" )} ), Properties( 8, {Line Color( 14 ), Marker( "X" )} ), Properties( 9, {Line Color( 14 ), Marker( "Y" )} ), Properties( 10, {Line Color( 9 )} ), Properties( 11, {Line Color( 9 ), Marker( "Y" )} ) )} ), Dispatch( {}, "400", LegendBox, {Legend Position( {20, [0, 1, 2, 3, 4, 5, -1, -1, -1, -1, -1, -1], 21, [-3, -3, -3, -3, 6, 7, -1, -1, -1, -1, -1, -1]} ), Position( {0, 1, 2, 3, 4, 5, -1, -1, -1, -1, -1, -1, -3, -3, -3, -3, 6, 7, -1, -1, -1, -1, -1, -1} )} ) ) ) )} )
tova
@tova wrote:
Thanks!
	{New Script(
		Graph Builder(
			Size( 1564, 941 ),
			Variables(
				X( :Nozzle ID ),
				Y(
					Side( "Right" )
				Y(
					Position( 1 ),
					Side( "Right" )
				Overlay( :Color ),
				Color( :Color )
			Elements(
				Dispatch(
					"400",
					ScaleBox,
					{Legend Model(
						20,
					), Legend Model(
						21,
				Dispatch(
					"400",
					LegendBox,
					{Legend Position(
					), Position(
