BookmarkSubscribeRSS Feed
jmp_ingbean
Oct 23, 2013
using pick file: filter list not working?
I'd like to filter the files my users can open, as most apps do, when I use pick file -- but when I add any filters to the filter list, all files appear grayed out, not just the type I specified in the filter list...
eg, I want to only allow them to select files of type "sqlite"
db_file = Pick File( "choose database file", "", {"sqlite files|sqlite"});
but in fact all file types are grayed out when script is executed, and also, I dont see the expected dropdown in the file dialog box where you choose the file type you want
using JMP 9 on mac os 10.8
suggestions?
thanks
Jeff_Perkinson
Community Manager
Jun 23, 2011
Re: using pick file: filter list not working?
Hi jmp_ingbean,
That's interesting. I can make it work with other file extensions but for some reason I can't get it to work with .sqlite and .db3.
Contact JMP Technical Support and they can investigate and tell you what's going on.
-Jeff
-Jeff
