BookmarkSubscribeRSS Feed
guy_yosef
Jul 16, 2014
using modal to create data base connection
Hi
i am trying to create data base connection and data quary using modal
so far i cant retrive the modal text
for example
thi ssi my connection quary:
dbc
= Create Database Connection("DSN=DB;UID=guy;PWD=passguy;MODE=SHARE;DBALIAS=DB;");
when i try to make a quary so other ppl that dont use JSL can connect to data base i cant retrive the UID
i try:
New Window("USER ID", <<Modal, Text Box("insert user ID"), variablebox = Text Edit Box());
userID = variablebox <<get ;
show(userID) ;
but all i get is:
userID = .;
is there a way to create data conection and excute SQL script using new window? (for ppl that are not using JSL)
thanks
David_Burnham
Jul 13, 2011
Solution
Re: using modal to create data base connection
Hi Guy
You just have syntax error.  You need to use the message "get text", not "get"
Dave
-Dave
David_Burnham
Jul 13, 2011
Solution
Hi Guy
Dave
-Dave
guy_yosef
Jul 16, 2014
thanks
its works fine (took me a while to find the concatenate:)
userID = variablebox <<get text ;
abc = Create Database Connection("DSN=DB;UID="||userID||";PWD=passguy;MODE=SHARE;DBALIAS=DB;");
