BookmarkSubscribeRSS Feed
qt
Oct 17, 2012
using column names in loops
Dear JMP experts,
I have a table with many repetitive columns:
A_X1_Y1, A_X1_Y2, ....A_X1_Y99, A_X2_Y1, A_X2_Y99, ...
B_X1_Y1, B_X1_Y2, ....B_X1_Y99, B_X2_Y1, B_X2_Y99, ...
i.e. Xi, i=1, 99, Yj, j=1,20,
If I want to add multiple columns:
C_Xi_Yj = A_Xi_Yj - B_Xi_Yj
C_?, where C_? = A_? - B_?
Can I use loop with Xi, Yj, or I can use something even more abstract, like: C_? = A_?-B_?
Thanks,
Qian
ms
Jun 23, 2011
Solution
Re: using column names in loops
Check out the function Evalinsert(). It can be useful when specifying formulas that depends on e.g. counter.
Example with formula columns:
// make example table
dt=new table("test");
for(i=1,i<=3,i++,
  for( j=1,j<=4,j++,
  dt<<new column("A_X"||char(i)||"_Y"||char(j), numeric, values([5,6]))
for(i=1,i<=3,i++,
  for (j=1,j<=4,j++,
  dt<<new column("B_X"||char(i)||"_Y"||char(j), numeric, values([2,2]))
// Add formula columns
f=expr(parse(evalinsert("A_X"||"^char(i)^"||"_Y"||"^char(j)^-B_X"||"^char(i)^"||"_Y"||"^char(j)^")));
for(i=1,i<=3,i++,
  for( j=1,j<=4,j++,
  dt<<new column("C_X"||char(i)||"_Y"||char(j), numeric, formula(eval(f)))
qt
Oct 17, 2012
here is my failed trials, someone please help:
for ( i = 1, i <= 3, i++,
     for ( j = 1, j <=4, j++,
     col_new_name="C_"||char(i)||"_"||char(j);
     data table (dt_out) << add multiple columns (col_new_name, 1, "Numeric");
      parse (col_new_name) << formula ( ascolumn (parse("A_"||char(i)||"_"||char(j)) -
                                                            ascolumn (parse("B_"||char(i)||"_"||char(j)) );
The columns with corrected names are added to my table, but the formula is just literally:
parse("A_"||char(i)||"_"||char(j))-parse("B_"||char(i)||"_"||char(j)
I also tried eval(parse (*)), without 'parse', without ascolumn, etc. none is working.
Please help.
Thanks,
Qian
ms
Jun 23, 2011
Solution
for(i=1,i<=3,i++,
  for( j=1,j<=4,j++,
for(i=1,i<=3,i++,
  for (j=1,j<=4,j++,
for(i=1,i<=3,i++,
  for( j=1,j<=4,j++,
qt
Oct 17, 2012
Thanks!
This evalinsert really helps. Now the code is working!
Best regards,
Qian
ms
Jun 23, 2011
For very large tables a solution based on matrix operations is probably more efficient.
An example;
// The script assumes that the columns are in the right order: first all A's then all B's in the same order
//dt<<reorder by name;
n=ncol(dt);
AB=dt<<get as matrix;
C=AB[0,1::n/2]-AB[0,n/2+1::n];
dt << set matrix(C);
for(i=1,i<=3,i++,
  for( j=1,j<=4,j++,
  col=Column(n+1); col<<set name("C_X"||char(i)||"_Y"||char(j)); n++
qt
Oct 17, 2012
It takes me a while to understand this. It is a very cool idea.
Thanks!
An example;
n=ncol(dt);
for(i=1,i<=3,i++,
  for( j=1,j<=4,j++,
