learning_JSL
Level V
trying to use JSL to save prediction results to a new column based on a model fit
Hi all - I am trying to save prediction results to a new column in my data table based on a model regression fit.  I have tried numerous configurations and the JSL debugger but the results do not end up in the newly created column.   I think I am missing something simple.  Thanks in advance for any assistance.
Here is my script:
dt = Open( "C:\ fit model100621.jmp" );
New Column( "New Predicted", Numeric, "Continuous", Format( "Best", 12 ) );
Fit Model(
    Y( :BACT ),
    Effects( :VAR1, VAR2, :VAR3 ),
    Emphasis( "Effect Leverage" ),
    Run
obj << Prediction Results;
Close( dt, save( "C:\ RESULTS of fit model100321.jmp" ) );
learning_JSL
Level V
Re: trying to use JSL to save prediction results to a new column based on a model fit
I'm just beginning to learn JSL.  I needed to add text (Obj =) in front of Fit Model for it to recognize the model and results.
So...I'm all set.   Thanks all.
learning_JSL
Level V
