Our World Statistics Day conversations have been a great reminder of how much statistics can inform our lives. Do you have an example of how statistics has made a difference in your life? Share your story with the Community!
eveyja
trying to make data table invisible
I am trying to get rid of the popup data tables that are created when I make spline coefficients using the "spline coef()" function below.
I've tried lots of combinations of "invisible" and various syntax but can't seem to get the data table to disappear.  It pops up as "AOPMean_Spline" and if I don't name it that, it pops up with a default title.
Any ideas?  thanks!
-Jeff
dt = AOPMean_Subset;
Current Data Table (dt);
Y = Column( "Measurement Results with Conversion Formulas" ) << GetAsMatrix;
X = Column( "DateTime" ) << GetAsMatrix;
coef = Spline Coef( x, y, 1e+18 );
dtcoef = As Table(coef);
dtcoef << Set Name ("AOPMean_Spline");
Column( dtcoef, "Col1" ) << Set Name( "X" );
Column( dtcoef, "X" ) << Data Type (Numeric, Continuous, Format( "yyyy-mm-ddThh:mm:ss", 19, 0 ), Input Format( "yyyy-mm-ddThh:mm:ss", 0 ));
Column( dtcoef, "Col2" ) << Set Name( "A" );
Column( dtcoef, "Col3" ) << Set Name( "B" );
Column( dtcoef, "Col4" ) << Set Name( "C" );
Column( dtcoef, "Col5" ) << Set Name( "D" );
eveyja
Re: trying to make data table invisible
It formatted my text with an "@" for some reason : I added a few spaces below to avoid this:
ian_jmp
NamesDefaultToHere(1);
m = dt << getAllColumnsAsMatrix;
dt2 = AsTable(m, << Invisible);
Wait(2);
dt2 << NewDataView;
Wait(2);
Close(dt2, NoSave);
eveyja
Thanks Ian, I found a different way around this but I'm sure your method works too!!
Article Labels
