santhu1501
troubleshooting a script on JMP analysis graphs and charts
New Bitmap Image.bmpCan anyone please help me troubleshoot this script on JMP for automated analysis charts. Debug shows the column names are not identified, but those are the existing column names on the data table, not sure what is wrong on this.
gzmorgan0
Re: troubleshooting a script on JMP analysis graphs and charts
From your debug screen, it is telling you the column "Load Max dT/dV" does not exist, or it is having a problem with it.  Here are few things to look at:
  • In your debug screen i=2 and selRows =2.  Make sure that is correct?
  • Check that the displayed current data table is correct.
  • Check that you have the correct name and data type for Load Max dT/dV. Are their extra spaces in the name, leading, trailing, spaces.
  • If all of that looks good, change :Name()  to  Column("Load Max dT/dV")[] (left,right bracket) or As Column(:Name("Load Max dT/dV") )
gzmorgan0
I believe something is wrong with your column name.  Here is an example where I added spaces, change teh modeling type and data type and the only way I can reproduce this error is when I specify a column that does not exist in the table.
6 REPLIES 6
gzmorgan0
gzmorgan0
Which version of JMP are you using?
santhu1501
its JMP Pro12, Thanks
gzmorgan0
santhu1501
Thanks a lot for reproducing this error and checking for me. You are correct, I just realized that, in my data table, column name slightly different,
I have it in data as "Load dT/dV Max" but in the script "Load Max dT/dV"
santhu1501
Thanks a lot, I found the error. As you said, its mismatch in my column name.... :-)
