Hi Justin:
JMP 9 makes it nice and easy to bring in a single envirionmental variable on Windows e.g.
user = Get Environment Variable("USERNAME"); show(user);
If prior to v9, one way ...
// write the values to a ASCII file
SaveTextFile( "C:\temp\deleteme.bat",
"set > C:\temp\x.txt"
Open( "C:\temp\deleteme.bat" );
// bring 'em all in a data table
dt = Open( "C:\temp\x.txt", End Of Field (Other), EOFOther ("="), labels(0),
Columns(Name=character(20), Value=character(200)) );
// display desired name/value pair
For Each Row( if(:Name=="USERNAME", show(Name, Value)) );
For a "bit more involved example" to go out and grab 'em all and stuff 'em in an array see:
Accessing the power & functionality of the MS Windows API via the JMP LoadDll function @ NESUG, 2010
http://www.nesug.org
http://www.nesug.org/Proceedings/nesug10/ad/ad04.pdf
Best Regards,
-Matt
